Questions about roller rocker installation. - Mustang Evolution
Old 12-15-2003, 09:52 AM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
If I get 1.8" non adjustable roller rockers, would I need anything else?
I've been seeing shims and all kinds of stuff, but I don't know what I need. I've read on the site that the stock springs will work but what else would I need?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 12-15-2003, 10:55 AM   #2
on a stock cammed car?
nothing but the rockers.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 12-15-2003, 11:27 AM   #3
Region: Iowa
The rotating assemply and heads are all stock. Then I won't need anything else?
Cool, thanks.
When would you need shims and stuff?
Old 12-15-2003, 11:32 AM   #4
shims usually if you have a big cam and you dont upgrade pushrods. But new pushrods would eliminate the need for shims.
New Hottness
1999 V6 5-speed
Wrecked
Old 12-15-2003, 12:03 PM   #5
Danger Dude's Avatar
new pushrods dont necessarily prevent the use of shims. I have a big cam, longer rods and shims
Old 12-15-2003, 01:51 PM   #6
Region: Iowa
Just going to 1.8 roller rockers I won't need new pushrods?
Old 12-15-2003, 02:59 PM   #7
New Hottness
1999 V6 5-speed
Wrecked
Old 12-15-2003, 04:17 PM   #8
You are correct!!!
Old 12-15-2003, 04:22 PM   #9
does anyone have a link to how you install roller rockers? the write up in the how-to section doesn't work. :
2001 Zinc Yellow V6 Coupe
15.9 @ 84 MPH.... yes, I did lose MPH if you were wondering...
The 'other' site that I visit http://www.cponygo.com :mrgreen:
jefflouis is offline   Reply With Quote
Old 12-16-2003, 07:23 AM   #10
Region: Iowa
You know, I just wanted to say how much I like this site. This place rocks,
Thanks guys
Old 12-16-2003, 08:09 AM   #11
Monkey's Avatar
give it a couple days. we're undergoing a server change (hopefully the last one ever!) and then it will be back up in all its glory
Old 12-16-2003, 11:30 AM   #12
RGR
Send a message via AIM to RGR
http://www.supersixmotorsports.com/P...stallation.pdf
This might help if U have adobe acrobat reader...
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
After Turbo installation... Ibanezplayer272 Pre-2005 V6 Mustang 13 07-14-2007 12:25 AM
CD Player installation nbennett Pre-2005 V6 Mustang 2 05-21-2007 08:55 AM
Supercharger Installation hawks05 1996-2004 Mustang GT 15 01-16-2007 08:19 AM
suspension installation I_luv_HP&trq Pre-2005 V6 Mustang 15 09-26-2005 05:54 PM
Will a roller rocker from a 5.0 (1.72:1) fit an 00 3.8l? tire Pre-2005 V6 Mustang 15 11-26-2003 02:56 PM
08:17 PM
