Exhaust is cut off from y-pipe back. - Mustang Evolution
Old 03-23-2015, 08:19 PM   #1
markerss232's Avatar
I have a 96. Auto. 3.8. Still have the stock exhaust system except no muffler cherry bomb of sorts swap. While doing some over haul work I found the previous over had the whole exhaust welded into one large section. Poorly done as I broke it off at the end of the y pipe. First notice the cars power increased massively. I thought with less back pressure. As for just the y pipe it would run poorly. Exhaust wasn't clogged cats are still good. Why? And for a replacement. I read a lot about true dual exhaust systems? Any opinions or suggestions?
Sent from my iPod touch using Mustang Evolution
markerss232 is offline   Reply With Quote
Old 03-24-2015, 12:09 PM   #2
superdrift's Avatar
Well if you wanna do it the right way the first time get longtube headers, prochamber midpipe and flow 40's
superdrift is offline   Reply With Quote
Old 03-24-2015, 03:03 PM   #3
Or just go all Mac with no cats H Pipe and ceramic mac long tubes
fordmustang3.8 is offline   Reply With Quote
Old 03-24-2015, 03:20 PM   #4
superdrift's Avatar
His year sounds really good with the prochamber midpipe. I think that an offroad h will make it sound more like a v6.
Old 03-24-2015, 04:26 PM   #5
Right. I forget he has the single port, not the split port
But with that "Sounds like a V6" comment, well what else is it? It IS a V6. Embrace it, and show it off. It will never be a V8, but who cares? Make it your own. Make it faster than a V8. And it will always have the V6 rasp in the higher RPM's. Nothing will ever make that go away, unless you get a V8.
Old 03-24-2015, 06:27 PM   #6
superdrift's Avatar
Im trying to save him from everybody saying his exhaust is a fart can, to do that you have to make it sound as close to a v8 as possible
Old 03-24-2015, 08:09 PM   #7
There's no way around it. The V6 has that high rasp, and it always will.
The set up I was talking about will make it sound similar to a V8 on idle, and low RPM's, but we both know that once you rev it past 3K with Flowmaster's or MAC's it will sound raspy.
Only way to fix that? Cams. Get a cam and you will keep the same volume most likely. I'm getting cam work done on my vehicle in the summer. Can't wait.
exhaust
Should i cut my resonators off? Mustang32Bill 2011-2014 Mustang GT 11 12-02-2012 11:41 AM
Off road x pipe vs off road h pipe? Sppankyy 2005-2010 Mustang GT 13 11-05-2012 11:27 PM
cut off my pipes strike1980 Pre-2005 V6 Mustang 7 01-01-2006 10:08 PM
99 V6 going to have cats cut and pipe welded back in place with 40 series flowmaster? bpmadsx Pre-2005 V6 Mustang 18 05-17-2004 12:26 AM
Rev. Limiter Cut Off Donny B Pre-2005 V6 Mustang 10 12-25-2003 11:25 AM
12:11 PM
