Car stalls after start - Mustang Evolution
Old 03-25-2015, 05:22 PM   #1
phatmike's Avatar
Region: Nebraska
Every once in a while when I start my 97 the rpm's go up to about 1000 then drop to 0 and my car dies. This seemed to start happening when it got warmer out and the only way to keep it from dying is to rev it up or just start driving right away. Is it a vacuum leak or spark plugs or what?
phatmike is offline   Reply With Quote
Old 03-25-2015, 06:07 PM   #2
natestang07's Avatar
I would check for vacuum leak first. How is the idle after it has ran awhile?
Old 03-25-2015, 08:22 PM   #3
phatmike's Avatar
Region: Nebraska
That's the problem..it will die and I will have to restart it. If I Rev it up a couple times to around 4,000 the idle will go back to 750 and idle correctly
Old 03-25-2015, 08:27 PM   #4
I would start with vacuum leak for sure
Old 03-26-2015, 10:55 AM   #5
phatmike's Avatar
Region: Nebraska
How would I go about checking that?
Old 03-26-2015, 11:52 AM   #6
It is kind of hard if it won't hold an idle. If it does hold and idle you can spray carb cleaner around. When it hits the leak it the idle will smooth out and soundhealthy. Or you could try feeling around and maybe get lucky and visually see it
Old 03-26-2015, 02:58 PM   #7
phatmike's Avatar
Region: Nebraska
Alright thanks I'll try that
1998 V6 3.8 Stalls after 15 minute drive Cardmont Pre-2005 V6 Mustang 4 08-27-2014 02:59 PM
stalls after warm up captain78 1979-1995 Mustang GT 3 03-13-2013 01:12 PM
Runs good but stalls after warm start up Ironman121388 1979-1995 Mustang GT 4 04-07-2012 09:15 AM
i start the engine and it runs for 5 seconds but then stalls out Pascullon Pre-2005 V6 Mustang 16 03-18-2011 10:41 AM
Code reading? and Car that idle Lobes and stalls stick0014 Pre-2005 V6 Mustang 4 09-03-2004 08:33 PM
05:43 PM
