Is it dying? - Mustang Evolution
Old 08-05-2008, 08:43 AM   #1
Region: Oregon
Is it dying?
My '99 sixer, seems to be having a lot of issues as of late. Here's what I've done to it to start. (Engine wise)
Delta Diablo chip
MAC cold air intake
Dual exhaust
(sorry that's it thus far)
Car has 66,000 miles.
During acceleration I am getting, what seems to be, a lot of valve noise. The car shutters and jerks along as I am accelerating. Lot's of misfires. I get this in either chip mode, using reg gas or super. About 2000-3000 miles ago I replaced the spark plugs.
Where should I go from here? Tomorrow I'm planning on looking through the engine bay to look for an obvious signs of wear on either wiring or vacuum lines, and make sure the filter is clean. Anything else I should look for?
Chris
chrisinbeav is offline   Reply With Quote
Old 08-05-2008, 09:05 AM   #2
Re: Is it dying?
I would revert to the stock program and remove the programmer/chip for now to ensure thats not it. Check the plugs and make sure they look ok and are gaped right.
If you still have issues check your coil pack/wires~
Old 08-05-2008, 11:06 AM   #3
Herbstang's Avatar
Re: Is it dying?
Like Brandon suggested pull the chip !! If your using one of the tune that came with the chip it may not be right for you .Most can tunes suck Spend the money and get it on a dyno
Do an injector cleaning, check the EGR system Or it could just be cheap gas run 93 your problem really sounds detonation which produes pinging and even knocking sounds
Do Not Mix Grades of gas you can't run 87 stock then switch to chip mode and expect it to run right
Old 08-05-2008, 06:53 PM   #4
Region: Oregon
Re: Is it dying?
Unless the chip has failed I doubt that is the problem. The chip went in the car at around 10,000 miles... maybe even less. It's been in for years with no problems. Within the last 6-10 months is when things started going bad.
'99 V6;
Diablo Delta Chip, MAC cold air intake, Custom dual central exhaust, Custom rear bumper to accomodate the exhuast, subframe connectors, Ford Racing FR500 wheels, indiglo guages, billet shift knob, custom stereo, Mach I chin spoiler, and that's all! (for now)
Old 08-05-2008, 07:17 PM   #5
Kiljosh's Avatar
Re: Is it dying?
This changes things. I really have no other input besides whats already been said...
Old 08-06-2008, 06:06 AM   #6
Herbstang's Avatar
Re: Is it dying?
Pull the chip and see how it runs. At least that way you have eliminated that as a cause.Still sounds like a detonation problem to me
Old 08-06-2008, 06:47 AM   #7
Re: Is it dying?
dont assume anything, usually that leads to issues. You simply never know~ you can do other things first if you wish just keep it on the table.
Old 08-06-2008, 06:53 PM   #8
Kiljosh's Avatar
Re: Is it dying?
Well what does it take to remove and reinstall a chip? 15 minutes? Might as well if these cats are saying it could still be the problem..
Old 08-08-2008, 10:01 AM   #9
Region: Oregon
Re: Is it dying?
First I turned the chip off...
No difference.
Then I pulled it...
No difference.
Hopefully later today I can start checking some of the other items.
Chris
'99 V6;
Old 08-08-2008, 01:01 PM   #10
Herbstang's Avatar
Re: Is it dying?
No difference.
Then I pulled it...
No difference.
Chris
Well that's one issue closed
Old 08-26-2008, 07:36 PM   #11
Region: Oregon
Re: Is it dying?
A little update.
I finally had a chance to check the gap on the plugs. They all need to be re-gaped. They are now at .52. I also replaced the fuel filter, which needed to be done anyway.The return airline off of the CAI had a crack in it so I replaced it as well...
Guess what?
No change. I'm really starting to get frustrated.
A couple of have mentioned the EGP system, how do I go about testing for that without randomly starting to replace parts?
Chris
'99 V6;
Battery Light/Car Dying megax29 Pre-2005 V6 Mustang 14 09-01-2007 12:16 AM
I think we are dying... n8r Pictures and Videos 12 05-18-2007 09:28 AM
P2P slowly dying out Thomas91169 The Bar 16 08-25-2005 03:10 AM
Dying laughin here! Why not to post your pic on the internet! 03redfire cobra The Bar 12 05-15-2004 07:33 PM
04:55 PM
