Heater core water return hose - Mustang Evolution
Old 04-10-2015, 12:40 AM   #1
Iryan7's Avatar
My water return hose is leaking antifreeze from the plug (that plugs into the hole in the fire wall) and I was wondering if I should buy an oem hose and plug, just buy the hose from advanced auto and hose clamp it on, or is there a way to take the plug off and just hose clamp it on? Thanks in advance for any help Click image for larger version
Name:	ImageUploadedByMustang Evolution1428644385.902812.jpg
ID:	179608Click image for larger version
Name:	ImageUploadedByMustang Evolution1428644405.617519.jpg
Iryan7 is offline   Reply With Quote
Old 04-14-2015, 03:17 PM   #2
Iryan7's Avatar
Bump
Old 04-14-2015, 03:36 PM   #3
I think that you will probably have to buy a new hose.
The advantage to the hose with a connector is that it is easier to install it in the cramped space.
You should be able to get a hose clamp on it though, so you can probably use the hose without the connector.
Vacuum hose help after heater core swap - CEL? NurmiCEO 1996-2004 Mustang GT 0 03-18-2015 03:16 PM
Heater core hose robin_gt 1996-2004 Mustang GT 0 09-22-2014 02:38 PM
Heater Hose Inlet/Return? BlackSmoke02 Pre-2005 V6 Mustang 2 10-14-2013 10:38 PM
Heater core replacement! AAstang 1996-2004 Mustang GT 2 03-09-2011 06:31 PM
Heater Core steedav6builder Pre-2005 V6 Mustang 0 08-06-2004 12:36 AM
12:18 PM
