Lowering - Mustang Evolution
Old 05-03-2015, 11:36 PM   #1
xrsfx's Avatar
Lowering
My car is stock height. I want it to be lowered where there's like a finger of a gap. How low is that & how can I do it ?
---------- Post added at 11:35 PM ---------- Previous post was at 11:35 PM ----------
04 vert
---------- Post added at 11:36 PM ---------- Previous post was at 11:35 PM ----------
Without getting new camber plates
xrsfx is offline   Reply With Quote
Old 05-04-2015, 08:09 AM   #2
superdrift's Avatar
Get coilovers
superdrift is offline   Reply With Quote
Old 05-04-2015, 09:42 AM   #3
xrsfx's Avatar
No money for coilovers
Old 05-04-2015, 10:41 AM   #4
superdrift's Avatar
$500 for raceland coilovers
Old 05-06-2015, 02:37 AM   #5
I have a 2013 and didn't want to lower it too much because I live in nyc and the roads are everything but decent. I went with lowering it 1inch all around with roush lowering springs. I'm barely able to stick in 2fingers. You might want to look for springs that drop your ride 1.5inches.
Raw Power
WiLL139 is offline   Reply With Quote
Old 05-06-2015, 08:00 AM   #6
superdrift's Avatar
Raw Power
The mustangs below 2010 have way more wheel gap than the 2010+ my 99 is lowered on ebaich pro springs and it is slightly higher off the ground than my friend's bone stock 2012
Old 05-06-2015, 10:09 AM   #7
Project Pony's Avatar
If you don't have the money for camber plates or coil overs, then you can't afford to lower your car correctly. At the very least some eibach camber bolts. (Dirt cheap on AM). And don't cheap out and not get it aligned.
[SIGPIC][/SIGPIC]
Old 05-06-2015, 10:27 AM   #8
xrsfx's Avatar
Where at ?
Old 05-06-2015, 10:39 AM   #9
superdrift's Avatar
Raceland.com
Old 05-06-2015, 02:33 PM   #10
xrsfx's Avatar
Went to a shop today & he said that camber plates are for more than 2 inches. To get to where I'll be at a comfortable drop is about 1 1/2 inch
Old 05-06-2015, 02:38 PM   #11
xrsfx's Avatar
Raceland.com
Thanks man
Old 05-11-2015, 09:01 PM   #12
You can achieve a 1-2" drop with lowering springs. Anything more and you'll want coilovers.
03 V6 with H&R SuperSports, no isos, cc plates = ~1.75-2 finger gap (front)
04 Mach 1 with SR Lowering Springs, no isos, no cc plates = 2-2.25 finger gap (all around)
Old 05-14-2015, 12:10 PM   #13
Mile high JDF's Avatar
This is a 2.5" front 2" rear drop. Caster camber plates are needed after a 1.5" drop. You can lower it without installing them but you're gonna get some really bad camber wear.
Edit: love the great triple post
ID:	182556   Click image for larger version
ID:	182559   Click image for larger version
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Lowering my car? white99 Pre-2005 V6 Mustang 7 03-16-2004 10:20 AM
Hey guys that are good at lowering, need help for poster DUW Zim The Bar 2 10-13-2003 09:54 PM
Bushings for lowering springs Blue232 Pre-2005 V6 Mustang 10 10-09-2003 12:33 PM
Where can i get lowering springs (01' Vert) Stang01 Pre-2005 V6 Mustang 3 09-30-2003 10:44 AM
Lowering Springs -- How Much? Stang01 Pre-2005 V6 Mustang 7 09-20-2003 12:07 PM
01:39 AM
