Sea foam - Mustang Evolution
Old 05-06-2015, 07:17 PM   #1
xrsfx's Avatar
Sea foam
What is it ? What can it do ? & where can I get it done
xrsfx is offline   Reply With Quote
Old 05-07-2015, 12:27 AM   #2
Mustang81596's Avatar
Basically it's this liquid you run through your gas and vacuum line that clean out your system. You go and buy a can from autozone or somewhere similar for like $7. If you do it and see smoke coming out of your tail pipe don't be alarmed, it's completely normal from burning out all the junk. Also, be sure to change your oil after
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 05-11-2015, 11:19 AM   #3
lookgoodgoslow's Avatar
And plugs!!
lookgoodgoslow is offline   Reply With Quote
Old 05-11-2015, 03:44 PM   #4
Kevin.Cook
Guest
Posts: n/a
I ran this on my old 3000GT and it helped smooth out the way it idled and such. Definitely recommended for older and high mileage vehicles.
Old 05-31-2015, 09:17 AM   #5
I just saw a good YouTube video of a guy doing this to his mustang, he showed exactly where and how to do it. He put some in the oil? Not sure about that. I do know you add some of the can to the gas.
The treatment helps clean carbon out of the engine, which i understand is a problem in this generation Mustang V6.
I'm going to do the same on my 2000 and will also report back.
Russ
2000 Mustang V6 Convertible
Sent from my Lenovo A7600-F using Mustang Evolution mobile app
ragtop_russ is offline   Reply With Quote
Old 05-31-2015, 10:45 AM   #6
Waylap1's Avatar
Region: New Hampshire
It's mostly hype and if you research videos where people actually bore scope their engine after treatments, there's very very little change to carbon deposits.
Here's where the smoke comes from....it's the oils in the Seafoam itself burning.
Here you see it used on a brand new engine yet it smokes exactly like people see and claim that's all their carbon being cleaned out.
Yeah...I'll spend that 8 bucks on lotto scratch offs instead.
Waylap1 is offline   Reply With Quote
Old 05-31-2015, 02:26 PM   #7
Pirate Bman's Avatar
So the question is what actually works for the purpose?
Pirate Bman is offline   Reply With Quote
Old 05-31-2015, 03:02 PM   #8
natestang07's Avatar
https://youtu.be/u6UeJXkzDW8
It worked for this guy. Not as dramatic as one would hope but some carbon did get burnt off
Old 05-31-2015, 06:37 PM   #9
I have done it twice in mine. A shop wanted to charge me 150 to decarbon my motor so i asked my dudes on ME if seafoam is the aame thing. Well i bought 2 cans and seafoamed the car and put new plugs, wires, oil and fuel filter for close to what they wanted just for their method
Old 06-07-2015, 08:27 PM   #10
Jaytraeg's Avatar
Personally, I've always loved Seafoam. Once, I had a misfire on one of my cylinders, and after using Seafoam in the intake, it ran totally fine. Turned out I had a gunked up injector.
Sent from my iPod touch using Mustang Evolution
Jaytraeg is offline   Reply With Quote
Old 06-20-2015, 02:30 PM   #11
So bottom line isn't it snake oil? By sounds of it doesn't sound too promising.
Old 06-20-2015, 04:00 PM   #12
It's a 6 dollar smoke show
Sent from my LG-D851 using Mustang Evolution mobile app
Old 06-20-2015, 04:11 PM   #13
Cooolbreeez's Avatar
I just watched this video the other day, not even sure why. I think I was bored.
Cooolbreeez is offline   Reply With Quote
Old 07-02-2015, 08:22 AM   #14
I have used it many years on small engines and swear by it. Follow direct as a stabelizer and also to de gunk injectors.
I will burn hot. I put too much in my 120 v AC generator and the muffler GLOWED RED. read directions please.
ibewbull is offline   Reply With Quote
Sea foam! Mathew r Wright 1996-2004 Mustang GT 23 03-30-2012 11:44 AM
Sea Foam... Mathew r Wright 1996-2004 Mustang GT 7 03-23-2012 09:36 PM
Sea foam ? shsfresh87 General Mustang Discussion 4 01-28-2012 11:46 AM
Sea Foam in vacuum line? afree05 2005-2010 V6 Mustang 1 12-12-2011 12:23 AM
Sea Foam 00vertstang Pre-2005 V6 Mustang 8 10-28-2004 06:19 PM
10:29 AM
