Window wont roll up - Mustang Evolution
Old 05-09-2015, 11:50 AM   #1
Dasan458's Avatar
Window wont roll up
I have a 2001 convertible that I recently purchased wrecked. I'm fixing it up now and recently bought a used passenger door. The door is off a 99, same color. Here is the problem.
The window will roll down but not up. I used switches from both old and replacement door and it wont work. The motor clicks when I press down but doesn't make any noise when I press up. But the driver's switch wont do anything to the window at all, no noise either.
I took the door cover off and use a small four-wheeler battery to roll it up so the motor is good.
My question is are there differences in the wiring between a 1999 and 2001?
What could be the problem?
Dasan458 is offline   Reply With Quote
Old 05-10-2015, 07:11 PM   #2
Dasan458's Avatar
I'm thinking it might be the driver's switch but I have no way of testing it. I cannot drive it anywhere currently.
Old 05-11-2015, 11:15 AM   #3
lookgoodgoslow's Avatar
I had the same issue.
The problem was the wire from the door to car was cracked due to opening and closing.
I spliced it back and it has been fine since.
lookgoodgoslow is offline   Reply With Quote
Old 05-12-2015, 07:05 PM   #4
Dasan458's Avatar
I checked that today and sure enough, there were two wires ripped out so I just swapped out the wire harness from the old door. Thanks a lot
Roll bars or no roll bars stanzmustang08 2005-2010 Mustang GT 8 10-01-2014 04:14 PM
My window wont roll down :/ FortyBrandon 1996-2004 Mustang GT 5 08-15-2013 03:43 PM
Window wont roll down 1lowGT 1996-2004 Mustang GT 2 06-22-2013 04:28 PM
Rick Roll meets Barack Roll sonic04edge The Bar 6 09-12-2008 07:23 AM
My window will not roll up/down, input? 5.0 stang 1979-1995 Mustang GT 2 02-20-2008 07:19 AM
05:52 PM
