Best oil & oil filter - Mustang Evolution
Old 05-09-2015, 03:08 PM   #1
xrsfx's Avatar
For a 04 v6 with 170k miles
xrsfx is offline   Reply With Quote
Old 05-09-2015, 03:25 PM   #2
Motorcraft oil filter is best. K&N, Royal Purple, and Mobil1 make good filters.
Synthetic oil with your car's oil weight rating, as long as you have no oil leaks.
BITOG is a reliable place to get lab results on any oil or oil filter out there.
- Bob is the Oil Guy - Bob is the Oil Guy
Old 05-10-2015, 11:01 AM   #3
Hampton CIT's Avatar
Wix filter and Mobil1 or Royal Purple oil in proper weight.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 05-10-2015, 12:03 PM   #4
The best answer is this, new clean oil, proper weight, and a good quality filter. Everyone will tell you that one oils better than the other or one filter is better than the other. I've got Mobil 1 full syn. 5W-30 and a Pennzoil oil filter on mine. For my car I did some research on the oil filters K&N offers a 11-17 PSI bypass oil filter and wix is a 21 PSI bypass. In other words it's a safety feature. In terms of oil its personal preference really. I'm planning on upgrading to royal purple or amsoil, still haven't decided yet. A full synthetic oil will be healthier on your engine but it doesn't require it. I've been running Kendall full syn. 5W-30 in my truck (189,XXX miles), truck runs great. It likes the Kendall synthetic more than the conventional Pennzoil 5W-30 I used to run. Now if you upgrade to a full synthetic, keep putting the synthetic oil in it. It's not healthy for the engine to keep switching from full synthetic to conventional or vise versa.
Adventure till you drop
Old 05-12-2015, 05:12 PM   #5
In our new mustang, we just use the factory oil and filter. In my older vehicle which is a 70 Blazer, Wix filters and Mobile 1 oil.
JWP69 is offline   Reply With Quote
Old 05-18-2015, 09:46 AM   #6
If you have no leaks, then you use synthetic, Motorcraft smemi-synthetic is good, Mobil1 ES, Amsoil ,
Motorcraft oil filter is best. Mobil1, K&N make great filters too.
Go to BITOG web to research lab results regarding ALL oils and filters.
BOB IS THE OIL GUY Lab Results:
Best synthetic oil and filter 96saskgtstang 1996-2004 Mustang GT 7 04-29-2012 08:22 PM
Is it okay to drive with an oil less K&N air filter for one day? berkeley General Mustang Discussion 1 03-09-2010 10:23 AM
99+ Mac Cai with 9" K&N Filter Justang Mustang Parts for Sale and Wanted 6 06-01-2006 04:07 AM
k&n filter & stock intake Warfire80 Mustang Parts for Sale and Wanted 0 05-18-2004 06:48 PM
cold air k&n filter PN/filter size tire Pre-2005 V6 Mustang 0 12-05-2003 05:37 PM
11:53 PM
