Rebuild engine? - Mustang Evolution
Old 05-18-2015, 11:13 PM   #1
PiojoA7x's Avatar
Rebuild engine?
I have a 03' mustang with 150k miles. For the past few months, it started to burn oil and throw blue smoke. It wasn't that bad until today it started to throw a lot of smoke. I did some research and it looks like my piston rings are shot. Now I know it's an expensive job to get that fixed because the engine has to be overhauled. Should I just get a used engine or rebuild my current one?
PiojoA7x is offline   Reply With Quote
Old 05-19-2015, 07:54 AM   #2
Dasan458's Avatar
Look into the 4.2 swap. It's basically the same engine just with a longer stroke. You can use the parts off of your 3.8 like heads, intake, etc...
Dasan458 is offline   Reply With Quote
Old 05-19-2015, 11:36 PM   #3
PiojoA7x's Avatar
It would be great to upgrade but don't have the money. Where can I get rebuild kits for my car?
Old 05-20-2015, 03:03 PM   #4
Dasan458's Avatar
If you buy a used 4.2 at a junkyard it can be cheaper than rebuilding your 3.8
Old 05-23-2015, 10:34 PM   #5
PiojoA7x's Avatar
No luck finding one at the junkyard. I'll be rebuilding my engine instead.
Old 05-31-2015, 02:32 PM   #6
Pirate Bman's Avatar
The motor is out of the f150 also so check that out. If I may suggest, tank your motor, do your work on it than sell it to buy an upgraded motor
Pirate Bman is offline   Reply With Quote
Old 10-06-2015, 09:27 PM   #7
PiojoA7x's Avatar
What engine oil should I use with my rebuilt engine? Should I use synthetic or conventional? 5W-30 or 10W-30?
rebuild of a recent rebuild Black99Snake SVT Mustang 12 08-20-2011 05:24 PM
Engine rebuild north of Chicago ? Rewbeez Classic Mustangs 1 07-23-2011 01:10 PM
donor rebuild vs current engine rebuild cash05_mustang Pre-2005 V6 Mustang 2 07-01-2006 01:09 PM
Recommend a shop for engine rebuild or swap In2dreamingbig 1996-2004 Mustang GT 2 09-27-2005 01:56 AM
engine rebuild tire Pre-2005 V6 Mustang 12 02-27-2004 06:54 AM
07:08 AM
