Replacing stock manifold on a super tight budget - Mustang Evolution
Old 05-22-2015, 07:45 AM   #1
I have the stock manifold on a 2001 v6/3.9L and it has a leak. Without having to modify the whole exhaust, is there a cheap/reliable alternative for headers that would fit the stock exhaust and any idea of the cost of reasonable labor for a mechanic doing it on the side? Thank you
oldguynj is offline   Reply With Quote
Old 05-22-2015, 09:50 AM   #2
SpeedyG's Avatar
Sorry man, when it comes to exhaust it gets pricey uses you get lucky on a deal.
I have heard that the manifolds on the 94-98 are actually headers and they can go on a 99-04 setup and are better than the stockers. Look into this to confirm.
As for labor it depends on location, parts, etc
SpeedyG is offline   Reply With Quote
Old 05-22-2015, 10:05 AM   #3
Ill look into the manifolds you listed. Thanks for the response
Old 05-25-2015, 09:11 PM   #4
baddbradd's Avatar
I have a set of 95 v6 factory headers I am going to sell soon...BUT the egr smog port is welded shut
2001 coupe
baddbradd is offline   Reply With Quote
Old 05-27-2015, 06:47 PM   #5
I went through two stock driver side headers due to them EXPLODING ! ! Dam pipe bombs. How bad is the crack? Sometimes the cheapest way to go is to braze the crack and save for a decent pair . If you do this, drill small holes on both sides of the crack first to prevent the crack from running
Sent from my SM-T230NU using Mustang Evolution mobile app
jake01roushv6 is offline   Reply With Quote
Old 05-28-2015, 09:35 AM   #6
The crack is extremely small,but I don't want to do more damage with the leak. I don't know much about this stuff, but I thought the leak could damage the engine and exhaust system if left leaking. I just do suburb driving and occasionally some 20 mile highway trips but I don't beat on it since I can't afford to lose what gets me around.
2002 mustang gt brakes tight at one wheel Bodytech73 1996-2004 Mustang GT 17 04-09-2015 07:09 AM
SLP exhaust a tight fit with MM Panhard bar mykal302 1979-1995 Mustang GT 5 08-21-2012 04:29 PM
Replacing stock fuel door with stock fuel door...help? MarshallYoung 2005-2010 V6 Mustang 13 07-23-2012 11:23 PM
What can happen if i tighten my valve covers on to tight? donald Classic Mustangs 5 08-21-2009 09:36 AM
4th gear tight Thomas91169 1996-2004 Mustang GT 12 02-13-2006 07:40 AM
02:27 AM
