Electrical system help. - Mustang Evolution
Old 05-29-2015, 08:42 AM   #1
6Banger2000's Avatar
Ok,
I have a 2000 V6, just replaced the starter last week. When it's cold it squeals when the starter engages, don't know what that means. But the bigger issue is now its not starting at all. When turned to acc, all accessories and lights come on as normal, but when I turn to on it clicks, all the acc's go off radio goes off and come back on but nothing else happens. Not a peep from the starter. I also lost my turn signals, but hazards work fine.
6Banger2000 is offline   Reply With Quote
Old 06-07-2015, 08:32 PM   #2
Jaytraeg's Avatar
Hmmm... I'd say check all of your fuses, and have your battery checked. Do the lights come on strong, or kinda dim? It sounds like you just have a dead battery to me.
Sent from my iPod touch using Mustang Evolution
Jaytraeg is offline   Reply With Quote
Old 06-07-2015, 09:16 PM   #3
Battery is fine.
Old 06-15-2015, 03:45 PM   #4
ruelas's Avatar
Please correct me if I'm wrong.
I always thought that a fluctuation of the indoor lights was a faulty alternator?
Now I did not publish this information but here is some help.
To perform the headlight test, start your car and turn on your headlights. With the vehicle in park, press on the accelerator while a second person observes the headlights. If the headlights flicker, dim or get brighter when the accelerator is pressed down, your alternator may be bad. No change in headlight brightness indicates that your alternator is likely fine.
Here is the source: How to Tell if You Have a Faulty Alternator - CarsDirect
ruelas is offline   Reply With Quote
Old 06-16-2015, 11:05 AM   #5
I never said anything about my lights. The battery and alternator are fine. I feel like you guys didn't really read what I wrote.
Old 06-16-2015, 11:18 AM   #6
ruelas's Avatar
"replaced the starter last week."
"it's cold it squeals"
"not starting at all."
"When turned to acc, all accessories and LIGHTS come on as normal,
but when I turn to on it clicks, all the acc's go OFF radio goes OFF and come back on but nothing else happens."
"I also lost my TURN SIGNALS, but HAZARDS work fine."
I don't have any real experience with the electrical side of the vehicle but it is well known that when we change anything on our cars we acknowledge that we may open a whole can of worms. But there is a man who can help you in that department. Wmburns he has a sea of knowledge with that department but he is not free. You can find him in any hand full of mustang forums. Good luck.
Old 06-16-2015, 11:00 PM   #7
Dasan458's Avatar
When you go to start the car, and all the lights go off, that's normal. All vehicles do that because all the power is being directed to the starter to turn the crank. Now it seems you might have a bad starter. Just because you replaced it doesn't mean it can't go bad. Check to see if you didn't accidentally hook it up wrong. and also was the starter new or used?
Dasan458 is offline   Reply With Quote
Old 06-17-2015, 07:12 AM   #8
I think I have a short in the cable from the battery to the starter.
Old 06-17-2015, 10:27 AM   #9
Dasan458's Avatar
If there is a short, you should be able to see where it is due to the melted plastic casing. But sometimes it doesn't short enough to do that. If you suspect it is a short I would take the wire off the car and inspect it and test it.
Chevy runs deep, Ford pulls them out
« Roll cage | Headers »
I have an electrical problem help!! 99saleen87 1996-2004 Mustang GT 17 03-11-2011 11:25 PM
Electrical help kack85 Pre-2005 V6 Mustang 5 01-28-2009 04:47 AM
electrical help! please! trickflow211 1979-1995 Mustang GT 0 07-31-2008 12:25 AM
Problem with electrical system kitslik Pre-2005 V6 Mustang 4 11-29-2007 09:56 PM
» Members Mustangs
Nokia
2014Vert
Ellie
sherv33
Add your Mustang
08:50 PM
