T5 question - Mustang Evolution
Old 06-02-2015, 08:45 PM   #1
2000v6stang's Avatar
Region: Iowa
T5 question
I bought a T5 trans on impulse and I cant remember what year gt the guy said it was out of so I did some research.
On the trans its says BorgWarner Automotive and there is a number under it 13-52-065 922. According to BritishV8.org that trans is out of a 84 Mustang/Capri 5.0 and the gear ratios are 1st 2.95 2nd 1.94 3rd 1.34 4th 1.00 5th 0.63. Those ratios match up to what Late Model Restoration says went into the 1984 Mustang LX and GT 5.0. I believe the gear ratios for my 2000 v6 are different so im assuming I bought a older version of the T5 than what came in my car.
So short version I think the T-5 is out of a 1984 5.0. Would I be able to swap it into my car (2000 3.8l) or would I be better off selling it and getting another one?
Blacking it out, MAC duel exhaust, SR CAI, Performance Automatic shift kit. And a long build list wrecked in July '14
2000v6stang is offline   Reply With Quote
Old 06-02-2015, 09:30 PM   #2
oxford5pointoh's Avatar
You can use it but you would have to change the input shaft. The lengths are not the same. The sn95 body puts the shifter back almost an inch more than the fox. That year transmission also doesn't have the updated blockers and is rated for less power. Honestly if you need it, run it. But it's probably worth it to find a newer same as your car junk years trans and sell this one.
IG @Oxford5pointoh
Old 06-02-2015, 09:33 PM   #3
Region: Iowa
Okay thank you that's what I thought and I'll probably sell it. I got it for $50 so I'll just get a newer one
Old 06-02-2015, 09:35 PM   #4
T5 question
Give this a read. Sounds like you are reading the case part number. Look at the tag that is bolted on where the tail shaft and main case meet. The numbers will tell you what you need to know
http://www.allfordmustangs.com/Detailed/349.shtml
IG @Oxford5pointoh
Old 06-02-2015, 09:38 PM   #5
50 bucks is a steal if works and even if it doesn't. I have 2 in my garage im rebuilding. I got both for 100 each, I thought that was good. But mine are post 1991, which is world class. And I am rebuilding them to the 93+spec
IG @Oxford5pointoh
Old 06-02-2015, 10:02 PM   #6
Region: Iowa
Thanks! Yeah it goes into all gears nicely and it turns smooth. I may pm you sometime I wanna crack this trans and rebuild it ether way so learning what specs I can build it to and what it intails would be useful.
Old 06-02-2015, 10:07 PM   #7
Yeah no prob man. I'm here
IG @Oxford5pointoh
Old 06-03-2015, 06:21 PM   #8
Region: Iowa
here is the number
Old 06-03-2015, 06:36 PM   #9
Looks like you said. Hmm let me see what I can dig up.
IG @Oxford5pointoh
Old 06-03-2015, 06:41 PM   #10
Region: Iowa
Thanks the number in the middle is a 5. Maybe for cast in 95
MAC long tube headers, pypes o/r H pipe, MAC catback, SR cold air intake, Performance Automatic shift kit, blacking out
Old 06-03-2015, 06:42 PM   #11
That's kinda what I'm thinking. I'd use it honestly.
IG @Oxford5pointoh
Question question!?!? AmericanBulldog Pre-2005 V6 Mustang 11 12-11-2013 08:24 PM
Wheel gap question and lca question Mdazi 2011-2014 Mustang GT 27 05-27-2013 07:11 PM
Wheel Question / possibly stupid question Rogue Slider Mustang Wheels & Tires 8 05-29-2012 12:21 PM
Question: I would like to know from you guys (See background and full question)? dumont75 General Mustang Discussion 16 03-03-2010 06:17 PM
Car question? Duh, of course it's a car question, silly!? imported_daman General Car Discussion 3 08-17-2009 06:40 PM
10:51 AM
