Stuck and confused - Mustang Evolution
Old 06-07-2015, 08:56 AM   #1
Stuck and confused
I have a 99 3.8l mustang it starts and drives when I accelerate it's fine just when I let off and try to ride at any speed it jerks and chugs and bogs down any help on where to start its completely stock no CEL
Sent from my c
ccto27 is offline   Reply With Quote
Old 06-07-2015, 10:26 AM   #2
Bravebowhunter's Avatar
I'd still go get it checked for a check engine light there could be a code there that the light isn't lighting up for. Fords can be weird like that they will let a problem go for a while before throwing the light on.
Bravebowhunter is offline   Reply With Quote
Old 06-07-2015, 07:23 PM   #3
CEL came on I got p0122 I'm going to get a new tps maybe it'll work if not then I'll try something else
Sent from my c
Old 06-07-2015, 08:21 PM   #4
Jaytraeg's Avatar
I would take apart your dash and replace the bulb for the CEL. I took mine apart to change the odometer gears and noticed that somebody removed mine, which makes me suspect fowl play...
Sent from my iPod touch using Mustang Evolution
Jaytraeg is offline   Reply With Quote
Old 06-11-2015, 11:20 AM   #5
I got a new tps and it's on but does not seem right problem is still there got a code for the tps out of range. Maybe a stupid question but is the little nubs inside where the blade inserts supposed to at least touch
Sent from my c
Old 06-11-2015, 11:50 AM   #6
Jbone007's Avatar
Try this!
Part 1 -How to Test the 3.8L Ford Mustang Throttle Position Sensor (TPS)
Jbone007 is offline   Reply With Quote
Old 06-11-2015, 12:01 PM   #7
Yes when you put the tps on you will have to what feels like turning the sensor when installing it. When you took the old one off you took the two bolts out and did the sensor twist? It's supposed to do when you reinstall the new one out it on off center of the bolt holes and twist it to put the bolts in this way the sensor is always resting on the throttle blade. Or else your sensor won't be working and you'll get the same symptoms
Old 06-11-2015, 12:02 PM   #8
Kevin.Cook
Guest
Posts: n/a
I would also clean the MAF, TB, and IAC Valve (if one is equipped).
Old 06-11-2015, 02:43 PM   #9
When I took the old one off its spring must have broke. Makes since to clean those since I'll have to take the tb off to twist it on
Sent from my toaster
H&R SS Springs and...well...now just confused nosympathy 2011-2014 Mustang GT 7 01-29-2013 02:34 PM
Was so excited, now stuck and frustrated (x pipe and cat delete issue) nosympathy 2011-2014 Mustang GT 56 10-04-2012 08:06 AM
First wiring project and I'm confused 89Saleen141 1979-1995 Mustang GT 24 07-27-2012 03:33 PM
I am new here! And a bit confused Ahmed ali khan New Member Introductions & Greetings 31 02-05-2011 01:28 PM
umm saw this video/site and confused Thomas91169 The Bar 10 09-21-2004 01:39 AM
11:27 AM
