Windstar upper intake swap! - Mustang Evolution
Old 06-12-2015, 03:52 PM   #1
Bravebowhunter's Avatar
Hello guys I'm in the middle of doing the upper intake swap and I've run into a problem the windstar intake hits my heater/bypass tubing! What did you guys do to fix this???
Bravebowhunter is offline   Reply With Quote
Old 01-28-2017, 06:03 AM   #2
i own a 2000 3.8 mustang and I would like detailed instructions on the installation I'm Patrick from tunnel hill ga my email is mustangt88@hotmail.com all help will be apreciated
thunder1965 is offline   Reply With Quote
Old 01-28-2017, 06:55 AM   #3
Are you a handy guy? Mechanically inclined?
Old 01-28-2017, 07:36 AM   #4
yes I am
Old 01-28-2017, 07:41 AM   #5
thanks for responding I just registered on this site about 3 hours ago
Old 01-28-2017, 07:43 AM   #6
I appreciate any help on the actual instructions installing it it is already modified ready to go on I'm very new to this site
Old 01-28-2017, 07:54 AM   #7
Well as long as you already have done the mods to the intake and made all the brackets you need for the coil pack, iac, throttle body spacer or a taller hood. It's a pretty simple bolt on mod. I did it in a couple hours but I had everything for the swap already made. I cut the mount for the iac off the new intake and plastic welded the hole closed and routed it through one of the other fittings. Make sure you have vacuum line handy you might need to reroute the vacuum lines
Old 01-28-2017, 10:15 AM   #8
thanks for taking the time to help me out
Windstar upper swap project misterpancho95 Pre-2005 V6 Mustang 10 01-28-2017 06:12 AM
Windstar intake swap SN95V600 Pre-2005 V6 Mustang 6 11-26-2012 06:44 AM
Windstar upper intake swap Supersixx Pre-2005 V6 Mustang 10 06-14-2011 05:21 PM
Windstar upper intake conversion Zebs5408 Pre-2005 V6 Mustang 14 04-11-2010 01:14 PM
windstar upper intake + stock hood? blackonblack Pre-2005 V6 Mustang 14 01-28-2010 07:39 PM
» Members Mustangs
'94 Pony
LavaPony
Ellie
Zhim
Add your Mustang
08:26 PM
