HELP !!! - Mustang Evolution
Old 06-16-2015, 05:16 PM   #1
superdrift's Avatar
HELP !!!
Went over a hard bump and now whatever this is has been leaking green fluid and hasnt stopped since i turned the car off.
superdrift is offline   Reply With Quote
Old 06-16-2015, 05:20 PM   #2
Not 100% sure the specific part but the green fluid is likely antifreeze. And that looks like some sort of heater hose
StarzTA17 is offline   Reply With Quote
Old 06-16-2015, 05:21 PM   #3
superdrift's Avatar
Im just wondering how do i get it to stop
Old 06-16-2015, 05:29 PM   #4
Noodles76's Avatar
Take it to a shop
Rollin' in my 5.0
Noodles76 is offline   Reply With Quote
Old 06-16-2015, 05:34 PM   #5
HELP !!!
That's a line for your A/C, and that green stuff is freon. That tank that it's coming out of is your A/C condenser. And yes get it to a shop.
Release the Kraken!!!
Old 06-16-2015, 05:37 PM   #6
superdrift's Avatar
All the shops are closed now
---------- Post added at 11:37 PM ---------- Previous post was at 11:36 PM ----------
Is there anyway to get it to stop making a leaking noise?
Old 06-16-2015, 05:39 PM   #7
HELP !!!
No, but it will run out of freon, then it will stop. And depending on how much your system will hold it might be a little pricey. Not including possible damaged piping. Plus your A/C useless without freon.
Old 06-16-2015, 05:41 PM   #8
superdrift's Avatar
Well its not leaking anything now it just sounds like air is coming out of that line
Old 06-16-2015, 05:43 PM   #9
HELP !!!
Freon also becomes a gas, depending on where it is in the A/C system.
Old 06-16-2015, 05:45 PM   #10
Is there an odor you're smelling?
Old 06-16-2015, 05:45 PM   #11
oxford5pointoh's Avatar
The green stuff isn't freon, it's dye and oil that is put in the system. But the freon or r134a or r12 will run out as stated before. If I were you, I would replace the broken line myself and then take it in to a shop to have it serviced. Save yourself the 10% mark up on parts and an hour labor charge.
IG @Oxford5pointoh
Old 06-16-2015, 05:45 PM   #12
superdrift's Avatar
So what should i do since i cant get it to anybody?
Old 06-16-2015, 05:47 PM   #13
Just let it leak. Nothing you can do. But I'd make sure it is outside while it does. It shouldn't take long before its done leaking.
IG @Oxford5pointoh
Old 06-16-2015, 05:48 PM   #14
Noodles76's Avatar
Also I wouldn't run the Ac until it is repaired.
Rollin' in my 5.0
Old 06-16-2015, 05:56 PM   #15
superdrift's Avatar
But all im wondering is it safe to run to the shop
Old 06-16-2015, 05:56 PM   #16
The "green stuff" was likely oil that is in AC system. The hissing sound is the Freon leaking out.
There is nothing that you can do. It would be more "environmentally friendly" if you could have rushed it to an AC shop so that they could properly evacuate the Freon, rather than releasing it into the atmosphere, but you would have to pay for new Freon anyways.
Is it leaking at one of the connectors? Or is the tubing cracked?
Old 06-16-2015, 05:57 PM   #17
Yes, doesn't effect drivability. Just no A/C.
Old 06-16-2015, 05:58 PM   #18
superdrift's Avatar
Well i got my ac serviced today so could this be a possible suspect?
Old 06-16-2015, 05:59 PM   #19
Noodles76's Avatar
Yes
Rollin' in my 5.0
Old 06-16-2015, 06:01 PM   #20
Yeah, your gonna want to take it back to who ever serviced it then
IG @Oxford5pointoh
Old 06-16-2015, 06:02 PM   #21
Once all of the Freon leaks out, there will be no pressure in the system to activate the pressure switch. Your AC compressor will not turn on if the pressure is too low to activate the pressure switch.
It won't hurt anything to drive it... Just your AC will no longer function.
Old 06-16-2015, 06:05 PM   #22
superdrift's Avatar
Ok well thanks everybody for the quick responses hopefully i can get this fixed tomorrow
Old 06-16-2015, 06:34 PM   #23
Noodles76's Avatar
IG @Oxford5pointoh
And tell them to unservice it.
Rollin' in my 5.0
Old 06-17-2015, 03:28 PM   #24
superdrift's Avatar
Update* the condensor and compressor are both unusable now and it would cost $400-$700 to fix it, so ended up going with an ac delete since i dont want to put that much money into the car before i sell it
Old 06-17-2015, 03:50 PM   #25
Well that sucks...
Adventure till you drop.
Old 06-17-2015, 04:43 PM   #26
Jbone007's Avatar
Take it to a different shop sounds like they are ripping you off! It sounds like they may be a fault anyway since it did not start leaking until after they serviced it. Don't think hitting a hard bump would crack a AC line. Just my 2 cents!
Jbone007 is offline   Reply With Quote
Old 06-17-2015, 05:18 PM   #27
Dasan458's Avatar
HOLD UP!!!
From what it looks like, it might not be cracked at all. There is a connection where the lines from the engine bay hook into the lines inside the car. That may have come apart or broken a seal.
The connection should look like this: Attachment 185176
It seems you are missing the security clamp that looks like this:Click image for larger version
I took a pic of another position to show you how to take it apart to check the o rongs:Click image for larger version
You will need a special tool to take it apart. You can get a kit at harbor freight or advanced auto:Click image for larger version
ID:	185173 Click image for larger version
You put it on the lines as shown:Click image for larger version
Then push the tool in and pop the connection off. I wasnt able to take any more pics cuz my camera died. But if you want to, I can show you what it looks like apart. Make sure You do this to the connection in the 1st pic. Or at least inspect it
Chevy runs deep, Ford pulls them out
Dasan458 is offline   Reply With Quote
Old 06-17-2015, 06:54 PM   #28
Ubnbit's Avatar
If I had just had it serviced and it was working before I went in, they'd be fixing my AC. End of story.
Old 06-17-2015, 07:09 PM   #29
richie895's Avatar
^this
IG @AyeOhGee
richie895 is offline   Reply With Quote
Old 06-17-2015, 07:45 PM   #30
superdrift's Avatar
Going to another one tomorrow
---------- Post added at 01:45 AM ---------- Previous post was at 01:44 AM ----------
It wasnt really working when it went in
Old 06-18-2015, 07:36 PM   #31
superdrift's Avatar
So what should i do? Either get an ac delete or advertise the car saying it needs a condensor?
Old 06-18-2015, 07:59 PM   #32
I think that I would just sell the car as is.
You don't need an AC delete unless you want to make the car lighter. The AC pulley will just "freewheel" and it won't hurt anything by not having the system functioning.
Old 06-19-2015, 06:38 AM   #33
Yeah the car is probable worth more with the a/c broken. Could be a cheap fix for a mechanic if they can find used parts. But I would be a pain in the *** for a buyer to reinstall if you rip everything out of the car
Old 06-19-2015, 08:15 AM   #34
Strange Mud's Avatar
be sure not to put the air flow switch in the windshield position...normally that will run the a/c to dehumidify. The low pressure switch should prevent it from coming on but never rely on safetys. It is ok to drive but NO a/c No air flow to windshield.
Old 07-04-2015, 01:21 PM   #35
Looks like just the quick connect popped apart..known ford problem,they make a clamp over fitting to prevent this.the shop that serviced the a/c most likely had nothing to do with this.the shock of the hard bump jarred the connection apart far enough to unseat the o-ringsas far as needing compressor and condensor most likely bull ****..take to another shop explain what happened when started leaking and point out connection..then with this estimate in hand go back to 1st shop for full refund and report to bbb
ALLYDRIVER1 is offline   Reply With Quote
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 04:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 06:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 11:37 AM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 04:35 PM
03:35 AM
