Car runs hot - Mustang Evolution
Old 06-26-2015, 07:26 PM   #1
Car runs hot
So my car has been running a little extra hot ao i thought maybe i should throw some dry ice in the reservoir tank and small chunks in the rad. What y'all think?
Sent from my LG-D851 using Mustang Evolution mobile app
Old 06-26-2015, 08:25 PM   #2
Dry ice is kind of expensive!
Just pack your engine bay with Walmart ice blocks.
That usually does the trick!
Old 06-26-2015, 08:29 PM   #3
Ubnbit's Avatar
Lol. Just run it. It'll be OK. That temperature Guage is only a suggestion.
Old 06-26-2015, 08:34 PM   #4
doyouevenforum
Guest
Posts: n/a
This is normal. Drain the coolant and drive around a few days with no coolant. It flushes the system and clears it up. Then its good to go.
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
Old 06-26-2015, 09:51 PM   #5
With the drain plug off right
Old 06-26-2015, 10:05 PM   #6
oxford5pointoh's Avatar
Auxiliary fan and radiator
Name:	ImageUploadedByMustang Evolution1435377918.780841.jpg
IG @Oxford5pointoh
Old 06-26-2015, 11:00 PM   #7
Toooo much weight on the nose. I saw this hood scoop at autozone and thought that maybe if i made a big hole it can be air cooled
Old 06-26-2015, 11:06 PM   #8
roushMarlon831's Avatar
Send a message via Yahoo to roushMarlon831
Is dry ice safe to be throwing it into the coolant tank?
roushMarlon831 is offline   Reply With Quote
Old 06-27-2015, 04:53 AM   #9
doyouevenforum
Guest
Posts: n/a
Correct
Car still runs after key is turned off and removed....... ShortBusKustomz 1979-1995 Mustang GT 12 02-28-2016 06:28 PM
My 1990 mustang runs hot, what could be the problem? jar39 1979-1995 Mustang GT 4 12-22-2011 12:37 AM
Hot hot! OutlawGT 2.3 Mustang 7 12-04-2011 10:39 PM
Engine runs hot for v6 Blackedout Pre-2005 V6 Mustang 2 02-20-2011 06:42 PM
What do you do when you completely flush out a cooling system and the car still runs hot? Dru General Mustang Discussion 5 04-02-2010 03:59 PM
09:44 AM
