96 3.8 headgaskey fix - Mustang Evolution
Old 07-07-2015, 09:11 PM   #1
has anyone ever solved the headgasket blowing problem on the early 3.8's.got lucky on this one no water in oil
ALLYDRIVER1 is offline   Reply With Quote
Old 07-09-2015, 09:32 PM   #2
whats the permenant fix,anyone?
Old 07-10-2015, 08:23 AM   #3
Project Pony's Avatar
If I recall correctly, the 94-95 had the biggest issues with head gaskets. Ford claimed the problem was fixed for the 96-98 model year. This was achieved by using higher torque specs on the bolts. Your 96 should be good, obviously you are having and issue. The only thing that comes to mind would be to make sure they are torqued correctly. I see a lot of v6 mustangs with junkyard motor swaps. Is it the original motor in yours, or is it possible someone had previously swapped in a 94-95 3.8? Hell after my 94 had the head gasket go, it got a 98 3.8 swapped in to prevent further head gasket issues. It never had any problems engine wise. Everything else broke, but the motor was good.
[SIGPIC][/SIGPIC]
Old 07-10-2015, 12:05 PM   #4
thanks,don't know history on motor.i bought it for grandson to drive to college two years ago.when tearing down noticed aftermarket gaskets
Old 07-11-2015, 03:29 PM   #5
It would be a good idea to pull out the radiator and make sure it's flowing alright. You can do a coolant flush then too. Throw in a tstat and make sure the water pump is good. Those motors don't like to get hot. How many miles are on it?
Sent from my SAMSUNG-SM-G920AZ using Mustang Evolution mobile app
[SIGPIC][/SIGPIC]
Old 07-11-2015, 09:24 PM   #6
New rad,new stat, new w pump new cooling fan showing 200k bought for grandson two years ago to dr to college.with the known problems with the odometer who knows?
Old 07-12-2015, 08:12 AM   #7
Since you've replaced all that stuff, there isn't a whole lot more you can do to prevent future gasket issues. As long as a quality gasket was used and it was done correctly you should be ok
[SIGPIC][/SIGPIC]
can you fix curb rash? Black00GT Pre-2005 V6 Mustang 4 02-24-2004 08:44 PM
Nobody can fix it...please help!!! BluStang6 Pre-2005 V6 Mustang 25 01-10-2004 10:15 AM
Nobody can fix...please help! BluStang6 Pre-2005 V6 Mustang 2 01-05-2004 04:11 PM
Gas pedal fix OR_Red98 Pre-2005 V6 Mustang 2 08-18-2003 07:59 PM
02:20 PM
