Emissions Testing with dual pipes - Mustang Evolution
Old 07-16-2015, 01:17 PM   #1
Iryan7's Avatar
Where I live, emissions testing is not mandatory. I am moving to Denver within a month. While living in Denver, I will have to pass emissions tests. I wanted to true dual pipe my mustang before moving, but will dual piping it cause it to fail emissions tests if I leave my catalytic converters on? Thanks in advance
Iryan7 is offline   Reply With Quote
Old 07-17-2015, 03:47 AM   #2
My car is true dual and passes emissions. I live in NC where emissions tests are required as well. Leave the cats on and you should be fine.
Sent from my Z970 using Mustang Evolution mobile app
Horerczy is offline   Reply With Quote
Old 07-17-2015, 04:29 AM   #3
Strange Mud's Avatar
it shouldn't fail if it's running good and you have cats. This is assuming sniffer tests...in CT we went to tests involving hooking a scanner up to the OBD port and checking the various sensors with that.
Old 07-31-2015, 05:48 AM   #4
In some jurisdictions that do emissions testing, there is a VISUAL component to the testing, so that even if your stuff passes the sniffer, if you run true dual on a car originally certified with a single system, they still won't pass it.
I don't know whether Denver is that anal or not.
California was a major pain in the arse in that regard. Hopefully, Denver isn't.
threepointeight is offline   Reply With Quote
Old 08-03-2015, 05:34 PM   #5
Mile high JDF's Avatar
Denver is really lazy with their emissions tests. Every time I've emissioned my car I never once saw them look under the car to check for cats. There is a local guy that passed with long tubes and a factory midpipe that had quite obviously been modified to fit. I highly doubt the testers will know enough about these cars to fail you for having true duals. As long as you still have cats and pass their test then they don't really care.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Illinois Emissions testing with O/R X pipe Langer1099 2005-2010 Mustang GT 4 06-11-2013 07:45 AM
Emissions testing 1996v6stang 1996-2004 Mustang GT 10 01-12-2013 11:47 PM
Florida emissions testing Copenhagen54 1996-2004 Mustang GT 5 08-26-2012 06:00 AM
A little depressed... emissions testing sucks...advice? NeedSomeMods 1979-1995 Mustang GT 28 07-04-2012 08:37 AM
When is a car exempt from Emissions testing? dagoberto General Car Discussion 1 04-04-2010 09:53 PM
09:36 AM
