window loose in track - Mustang Evolution
Old 07-19-2015, 03:57 PM   #1
on to the next thing to fix lol. my drivers window goes up and down fine but it also moves forward and backward. I pulled the panel and have found the plastic piece that keeps it lined up is broken. question is whats it called and where can I get one? thanks, dan
dcarr is offline   Reply With Quote
Old 07-20-2015, 06:54 AM   #2
yogibooboorange's Avatar
Are your windows power or crank style? You can get your part at Rock Auto and others. Provide a picture of the part if you can.
yogibooboorange is offline   Reply With Quote
Old 07-20-2015, 07:01 AM   #3
i have power windows and unfortunetly there is no way to get a pic withour tearing the whole thing apart. but its a plastic piece that slides in the rear channel
Old 07-21-2015, 08:58 AM   #4
You might find what you need here:
GLASS - DOOR for 2002 Ford Mustang
Old 07-21-2015, 09:04 AM   #5
thanks! i did see that before but cant tell which part it is, i think its #3. guess ill have to tear it aprt and try to get my phone in there to take a pic to really see. i just wasnt sure if it was a normal problem and people knew what i needed. thanks for your help
Old 07-21-2015, 09:14 AM   #6
Yea I had to replace the motor and regulator on my car (2002 Convertible). I discovered that the window glass has come loose from the channels it sits in. Ford used some sort of silicone to hold the glass in place. I was able to get the glass back into the channels but the front most one will not stay on (runs inside the front most vertical channel). I did not have any adhesive on hand, so I put everything together so I could at least raise and lower the window but it moves front to back like yours. I did in the mean time order window glass adhesive and later on this year, when close to time to park for winter, I will again tear apart the door and properly adhere the glass into the channels and then will have it fixed properly.
Old 07-21-2015, 09:20 AM   #7
mine is glued there still the very rear channel that runs up and down has a plastic piece that keeps the window lined up. that piece is whats broken.
Old 07-21-2015, 09:27 AM   #8
I know which piece you are referring to. That is not #3 on the diagram. #3 are stabilizers which adjust in and out to keep window from moving towards the outside and interior so that when fully up the glass does not bow out away from the moulding and sits properly in the weather strip. There is a youtube video that shows the proper way to adjust those. The part you are needing you may have to get from salvage yard. I would know more when you take pic of the part.
Old 07-21-2015, 09:31 AM   #9
ok ill have to tear into it, thanks.
Old 07-21-2015, 09:44 AM   #10
Here is a link for the video to adjust and align the window:
Old 07-21-2015, 09:45 AM   #11
Here is the video to R&R regulator/motor as well:
Old 07-22-2015, 12:28 AM   #12
Took a screen shot from the video. This is the part I need.
Old 07-22-2015, 06:37 AM   #13
I do not think the disk is a replaceable unit. You may have to go to junk yard and find that window bracket as a whole to glue onto your glass. Or just get another whole window glass. There is an option of making one as well.
Today. Hell. Breaks. Loose. wiarumas The Bar 14 10-23-2005 11:45 AM
Loose clutch & Ford says it's normal WhiteThang Pre-2005 V6 Mustang 5 02-21-2005 10:27 PM
Idiot on the loose 04MonteSS The Bar 25 02-16-2005 04:47 PM
theres a wallaby loose in severn where i live...wtf!?! Bane- The Bar 4 10-13-2004 02:58 PM
Reported Drunk on the Loose Shahrum The Bar 11 03-18-2004 10:39 PM
10:20 PM
