Mustang noise - Mustang Evolution
Old 07-21-2015, 11:05 AM   #1
kickerofdoom's Avatar
Mustang noise
A noise is coming from the rear can't tell if it's the wheel bearing or brakes, or rotor. A grind noise while driving and steering wheel pull to the right when brake hard. The front brake look ok and changed a wheel bearing for the front. The rear rotor look to be bad
Old 07-21-2015, 02:39 PM   #2
natestang07's Avatar
Probably need a new rotor and it could have messed the pad up as well. While you are replacing the rotor and pad you might as well do the other side as well.
bad squeaking noise on 3.8 01' mustang jumpman1203 Pre-2005 V6 Mustang 9 07-27-2015 01:03 AM
02 v6 mustang ticking noise after clutch replacement cadreamin Pre-2005 V6 Mustang 0 11-22-2012 04:39 PM
Clutch noise 02 mustang gt mkw037 1996-2004 Mustang GT 5 09-05-2011 08:14 AM
White noise :: 1968 Ford Mustang Shanes0406 Member Garages 0 06-15-2011 12:02 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
06:05 AM
