Suspension Kit for my car under $300 - Mustang Evolution
Old 12-19-2003, 09:45 AM   #1
Shahrum's Avatar
Send a message via MSN to Shahrum
w00t w00t I just got my Xmas bonus from work... $300!!! Well... $277 after taxes, but close enough!
Anyways... one of the things I'm planning on doing after I get my tax return in January is of course new wheels and tires. But I had also planned to save money from now until then to get a suspension upgrade/kit for my car.
Well... now that I have nearly $300, that might be enough to get the new suspension now!!
I had looked at Steeda's Stage 1 kit (springs, caster/camber plates, and strut tower brace) which I believe goes for a little over $400 on the Steeda site. I guess what I'm more concerned with here is better handeling, cause quite honestly, Mustangs handle like crap!!
So what do you all think? Another important thing to consider is my body kit. My front bumper already sits very low to the ground, so I don't want to lower too much. I believe the Steeda springs are 1.0-1.25 inches. Is this correct?
And if anyone has any other recommendations, please let me know. Thank you!
Shahrum is offline   Reply With Quote
Old 12-19-2003, 01:25 PM   #2
Shahrum's Avatar
http://www.stangsuspension.com/store/comersus_viewitem.asp?idproduct=275
What do you all think of that? For less than the Steeda kit... it seems to give soooo much more!
What's the quality like though? Cause these are supposed to be the same Ford parts put on the GT Bullits. Are these as good quality as something like Steeda or Eibach?
Old 12-19-2003, 06:34 PM   #3
Quality wise they are pretty much the same in most aspects.
There are better dampers out there but tokico's aren't bad. Its a good starter suspension I'd say.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 12-19-2003, 10:05 PM   #4
Dom
Dom's Avatar
Send a message via AIM to Dom
Well not everyon can afford Konis.
Old 12-20-2003, 01:30 PM   #5
fms c springs and mach 1 tokicos all around
Old 12-21-2003, 12:23 AM   #6
Dom
Dom's Avatar
I told him he should save alittle more.
Old 12-21-2003, 01:33 PM   #7
Rick0636's Avatar
I would have to ask what kind of sway bars those were personally, might be just regular GT sways, in that case get a pair out of a junk yard for a lot less. Bullitt struts and shocks are probably better all around than MachIs because the Mach I is more for for Drag racing.
Old 12-25-2003, 03:41 AM   #8
Dom
Dom's Avatar
Really for every say use you just need the GT rear sway bar.
Old 12-26-2003, 01:06 PM   #9
Rick0636's Avatar
Contrary to popular belief on this and 3.8 for some reason, matched sway bars, in my humble opinion, are much superior to unbalanced ones, its much better to have front and rear sway bars that match than to have a v6 front bar and a GT or cobra rear bar. Take note of my mods list, both my sway bars are COBRA bars, not a cobra rear and a GT front bar.
Old 12-27-2003, 01:27 AM   #10
Dom
Dom's Avatar
I'll have to keep that in mind if a Cobra come to the junkyard.
Just remember not to go to big on the sway bars. Don't want ya to pull a SUV here.
Old 12-28-2003, 07:53 PM   #11
Rick0636's Avatar
I have shortened end links, and my cobra front bar is actually smaller than my GT bar was, but stiffer.
Old 12-28-2003, 07:55 PM   #12
Rick0636's Avatar
Cobra rear bars have to come off a 98 or older, the 99+ have IRS and won't work.
Old 12-29-2003, 02:16 AM   #13
Dom
Dom's Avatar
Yea, already knew that. Not that dumb.
Old 12-29-2003, 10:39 AM   #14
Danger Dude's Avatar
Nice kit and a nice price
Old 01-04-2004, 01:25 PM   #15
I agree with rick, to a point. Remember that these bars are 'matched' on
that car with that weight and they're also matched to give understeer.
I'd rather have a neutral or slightly oversteering car so I would get a
bigger rear bar. It all comes down to if you want under or oversteer and
what other mods you have. Throw in a panhard bar and you have to
change things around even more!
-Mik
Redlined Performance Mustangs
Cylinder Head / Intake Porting, Camshafts, Pistons, Cold Airs/Pulleys
www.rpm-mustangs.com
http://rpm-mustangs.com/pictures/KEcrank.jpg
mikael is offline   Reply With Quote
Old 01-04-2004, 01:44 PM   #16
I second the motion. Then pick up some swaybars and get a good
alignment.
-Mik
Old 01-05-2004, 11:19 AM   #17
I third it !!!!!!!. I would also suggest looking into some C&C plates. after about 6 months I went back for a alignment check ( South Carolina roads are not the best) and they need further adjustment on the alignment and there was no more to adjust I now have UPR Shark Billit C&C Plates.
Suspension Kit megax29 Pre-2005 V6 Mustang 6 12-12-2007 01:30 PM
300 Second Trailor of 300 bluemustang The Bar 7 03-05-2007 07:15 AM
Bullit Suspension Kit electricstang The Bar 13 05-10-2006 11:39 AM
Bullit suspension kit cuban3jumper Pre-2005 V6 Mustang 11 07-19-2004 09:26 AM
the $300 reason my car stays garaged at night WhiteStang99 Mustang Audio & Video 59 03-09-2004 11:26 PM
08:27 AM
