mach sound tweeter question - Mustang Evolution
Old 07-29-2015, 03:34 AM   #1
i just got a set of the mach tweeters but the screw hole in my door that holds the pod in place is actually a square. where can i get a fastener for it or could i used a fastener used on license plates?
tyronekndrck is offline   Reply With Quote
Old 07-29-2015, 07:50 AM   #2
yogibooboorange's Avatar
You could probably use a license plate fastener as you mentioned. Just make sure when wiring them, that they only get upper range signal from radio unit. Do not splice them in with any other speaker as they are not made for mid or lower range and will blow. Just a word of caution. In the mach system, the tweeters are powered by their own amp. The larger speakers are powered by their own amps. I guess I should ask, what system do you have? Good luck with your install
yogibooboorange is offline   Reply With Quote
Old 07-29-2015, 11:54 AM   #3
I have aftermarket amps pushing mids and highs. But I plan on using either powerbass or Memphis tweets in there. They have models that fit right in, no mods required. Do you have a clue what the max watts on the stock ones are anyway
Old 07-31-2015, 06:39 AM   #4
Here is what the factory says about the system speakers:
Power Amplifier Section
Mach 460:
Ford Hi/Mid-Pass Amp - 2x60w = 120w Max. 2x30w = 60w Nom.
Ford Mid/Low-Pass Amp - 2x85w = 170w Max. 2x43.5w = 85w Nom.
230w / 13v = 17.7 amps Nom. 4 Ohms at 2% THD
460w / 13v = 35.4 amps Max. 4 Ohms at 2% THD
sound system 98 mustang mach tweeter daniel95 Pre-2005 V6 Mustang 1 11-05-2013 09:48 AM
(Rear Deck Tweeter Bracket) Mach 460 Tweeter Pod (Custom Bracket) HGFoxfire Mustang Audio & Video 3 04-14-2010 09:45 AM
Tweeter Location for ’09 Mustang Vert? Cruisinketch Mustang Audio & Video 0 04-09-2009 12:00 PM
Front door tweeter placement. Renegade 800 Mustang Audio & Video 2 10-09-2008 02:38 PM
Components... where to put the tweeter? Brent Mustang Audio & Video 18 07-13-2004 11:34 AM
09:48 AM
