POWER STEERING ? - Mustang Evolution
Old 07-29-2015, 01:16 PM   #1
POWER STEERING ?
ON A 96 MUSTANG V-6
when driving and after making a turn steering doesn't return to center without putting there with steering wheel.does the rack have a self centering valve like some cars do? or is ps pump the problem, power steering has normal feel otherwise.
ALLYDRIVER1 is offline   Reply With Quote
Old 08-03-2015, 05:36 PM   #2
Mile high JDF's Avatar
The steering wheel centering itself after a turn actually has to do with your alignment. If the caster angle is off then it won't return correctly.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-04-2015, 06:02 AM   #3
Mile High JDF is correct. You most likely have a caster angle problem.
In simplified terms, caster angle is the relationship of your tire's contact patch to the steering axis. A good mental picture of this is to think about the front wheels on a typical supermarket shopping cart, wherein the "contact patch" of the front wheels quite obviously trails the steering axis as you push the cart forward.
Increased caster = better straight line stability (less propensity to "wander") and more "self-centering" of the steering. . It also makes the tires lean into the corner when turned, in effect producing more negative camber when the wheels are turned. This allows you to use less aggressive Negative-Camber settings, thereby improving the tire contact patch for better braking and reduced tire wear when the wheels are straight.
On a New Edge Mustang running all stock parts with the strut towers not deflected out of whack from 11 to 15 years of life on the road, the stock caster angle is about 3.6 degrees; about 1,75 degrees on an SN95. That increase in caster angle from the 98 models to the 99-04 models is an example of Ford engineers responding to their customers, in a sense, because the stock castor angle on a Fox body was something like 1.25 to 1.7 and those of us who where road racing and autocrossing the things would run adjustable camber / castor plates with the max caster we could get, which was around 3.1 to 3.4 degrees. Ford simply built that in from 1999 to 2004.
There is just one teeny-weenie little problem, though.....
Unless you're running adjustable camber / castor plates, the castor angle isn't adjustable. This is one reason why I believe the addition of adjustable camber / caster plates should be one of the first mods made to these cars. The strut towers are almost sure to not be in the same OEM, "factory fresh" relationship with themselves and the rest of the unibody structure after a decade or more of road duty.
While you can have too much castor angle in theory, the reality on a New Edge equipped with adjustable camber / castor plates is that you can't get too much of it. When I set this, I don't even bother measuring it. I just push the tops of the struts as far back toward the rear of the car as I can get them. In doing that with the adjustable plates I run, the end result will be somewhere between 5.0 and 6.0 degrees. It's one of those "It is what it is" kinds of things and will be a little different an each individual car, but it can't be too much in the absence of major sheet metal surgery to relocate the strut towers on the unibody.
threepointeight is offline   Reply With Quote
Old 08-05-2015, 09:08 PM   #4
bump
Old 08-05-2015, 10:41 PM   #5
natestang07's Avatar
Why are you bumping this when you have an answer?
Old 08-06-2015, 06:49 PM   #6
mostly because would like other possible causes as the castor is correct,I have been alignment tect since 1969 and knew about castor.why are you concerned about my bump?
Old 08-06-2015, 08:20 PM   #7
I need to fix the caster on my truck.
Twin I-beam...
Old 08-06-2015, 08:38 PM   #8
Thumbs up
Twin I-beam...
any good alignment shop can fix you right up,back about '86/87 fords would scare the crap out of you because castor was wrong,almost as bad as the death wobble on jeeps
Old 08-07-2015, 04:28 AM   #9
It sure would have been nice to to know from your original post that you had already ruled out one of the most likely causes of your problem.
Since you're an alignment tech, and thus familiar with how the entire suspension system and steering system really work, I'm kind of shocked that you needed any help with this problem. I would think that you would be so familiar with the front suspension and steering systems that troubleshooting this from alignment settings to worn parts would be a second-nature kind of thing.
Good luck with your problem.
Where can I find steering damper for 66 manual steering? Daniod9 Classic Mustangs 11 11-06-2013 10:19 AM
Steering wheel shaking, power steering? toro 2011-2014 V6 Mustang 3 05-04-2013 06:31 PM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 04:38 PM
power steering issues WhiteStang99 Pre-2005 V6 Mustang 16 06-22-2004 06:08 AM
Difficulty installing presure line (power steering) 3.8turbo Pre-2005 V6 Mustang 0 11-03-2003 03:12 PM
10:59 AM
