Help! Right turn signal FAST while left regular speed - Mustang Evolution
Old 08-21-2015, 02:51 PM   #1
Good afternoon. Last few days my 2004 40th anniversary V6 has been driving me crazy. The right signal is FAST and then regular and then FAST -- it is presently in FAST mode. Probably should clarify, my family is driving me crazy mentioning it. Could there be something bigger going on? How can I fix this? Please help, I have only owned it 4 months. Got my tuner, set to street and my CAI. Love those mods. Thanks, Mark
nottiger007 is offline   Reply With Quote
Old 08-21-2015, 02:55 PM   #2
Kevin.Cook
Guest
Posts: n/a
Have you tried taking the bulb out and putting it back in? When my wife had a 2000, she had this issue. We tried that and ended up having to disconnect the battery for a bit and reconnect it.
Old 08-21-2015, 03:01 PM   #3
natestang07's Avatar
Did you check to make sure a bulb isn't out?
Old 08-21-2015, 03:05 PM   #4
I will check. Thank you.
Old 08-21-2015, 03:06 PM   #5
Eturner's Avatar
You have a Burned out light!..
Old 08-22-2015, 12:31 AM   #6
1slosix's Avatar
Burned out bulb or the flasher control under the dash needs replacing
carving corners like a boss
Old 08-22-2015, 03:56 AM   #7
Waylap1's Avatar
Region: New Hampshire
People still don't know that when it blinks fast it means one of the two bulbs (front or rear) is burned out?
Waylap1 is offline   Reply With Quote
Old 08-22-2015, 11:37 AM   #8
Waynes World's Avatar
Region: Utah
I had that problem w/a f150 I was working on, ended up being the grease ford put in the sockets had dried out. Cleaned up and put good dielectric grease back in sockets, he hasn't had the problem since.
Waynes World is offline   Reply With Quote
Old 08-25-2015, 09:17 PM   #9
1Mustang805's Avatar
yup burned out light bulb
1Mustang805 is offline   Reply With Quote
Old 08-26-2015, 06:22 AM   #10
yogibooboorange's Avatar
I had the same issue on a Mercury Mountaineer. As it turned out, the bulb was old, probably original, and the bulb would work intermittently. I replaced both rear turn signal bulbs with new and the problem went away. Bulbs are cheap, Replace the rear and front bulbs.
yogibooboorange is offline   Reply With Quote
Old 08-26-2015, 06:38 AM   #11
I'd like to think the fast flash letting you know the bulb is out is common car knowledge, I guess I was wrong lol. Might as well replace them all.
Old 08-26-2015, 07:19 AM   #12
Eturner's Avatar
Hey!.. We all start off some where!.. When I bought my first car I had to have a mechanic tell me why my blinker was flashing fast!.. 😏. He then had to convince me to change it out myself vs paying him $60 to do it!.. Hahahahaha.
Sent from Me and Only Me!.. 🍺
Turn signal help Doe_Rae_mi 1996-2004 Mustang GT 16 06-10-2015 02:12 PM
Front Left Turn Signal Not Working lowbwan 2011-2014 V6 Mustang 6 02-07-2015 06:53 AM
Turn signal flashes fast after halo light install Iryan7 Pre-2005 V6 Mustang 9 12-22-2014 04:40 PM
help! turn signal problem!! itsA4cylBro 2.3 Mustang 5 10-12-2012 07:36 AM
mustang turn signal help? 78survivor General Mustang Discussion 4 02-07-2012 03:25 PM
06:39 AM
