Oil Pressure Switch Leaking - Mustang Evolution
Old 08-26-2015, 05:32 PM   #1
Hello all,
This is my first post here at Mustang Evolution and assure you it wont be my last, since I mainly do all of my own work unless it is replacing suspension arms
Recently, my 2000 Mustang Convertible 3.8L had an oil gauge issue that fixed itself after about a week. I then noticed oil drips on my driveway prompting me to look under the hood. I couldn't find anything immediately so then proceeded to look under the car only to notice that there was a steady drip coming from above the oil filter. I inspected further and back to under the hood, noticed that my oil pressure switch connector is oozing oil out of it pretty steady while and after the car shuts off.
The switch and connector will be an easy fix if only I could reach the darned thing hehe . It is located behind the power steering pump .
I see no easy way to replace this issue with out removing the power steering... Is this correct? If so, is there an easy way to alter or slide the power steering pump out of the way?
I have released the serpentine belt and removed the 2 nuts that connect to the water pump and also one bolt that is connected to the alternator.. No luck on that..
Any help would be greatly appreciated!
SilverStang79 is offline   Reply With Quote
Old 09-09-2015, 01:39 PM   #2
Iryan7's Avatar
When I replaced mine I had to pull my power steering pump to get it out
Sent from my SM-G920T using Mustang Evolution mobile app
Iryan7 is offline   Reply With Quote
Old 09-09-2015, 09:12 PM   #3
Common problem,remove ps pump 30 min job start to finish
ALLYDRIVER1 is offline   Reply With Quote
a/c pressure switch 93mstnglx 2.3 Mustang 2 07-26-2016 12:41 PM
Need help! Take pic of ac pressure switch? Enorym 2005-2010 Mustang GT 16 08-20-2015 05:12 PM
New oil pressure sending unit, still 0 oil pressure Iryan7 Pre-2005 V6 Mustang 9 07-13-2015 03:15 PM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 05:03 PM
NX fuel pressure safety switch cuban3jumper Mustang Parts for Sale and Wanted 0 12-29-2006 12:04 AM
08:54 AM
