Left Taillight problem - Mustang Evolution
Old 09-05-2015, 04:27 PM   #1
Rubenfran26's Avatar
Something is wrong with my left taillights. the driver's side signals hyper flash, but the right signals and brake lights work fine. see photos
1. when i use my left turn signal, the front hyper flashes and only one taillight flashes which is the middle column but hyper flashes. also the left blinker hyper flashes on the dashboard
2. when i step on the brakes only one of the left tail lights illuminate, the right side works fine.
during the night, all taillights are illuminated but same issues as during the day
what could the problem be? is it a sensor issue or bulb issue
I'm planning to install LED Sequential taillights but it is on hold until i figure out what is wrong with my taillight. Thanks for your help
-Ruben
Name:	Tail light problem 3.jpg
ID:	190709   Click image for larger version
Name:	Tail light problem 4.jpg
Rubenfran26 is offline   Reply With Quote
Old 09-05-2015, 04:57 PM   #2
-Ruben
check grounds and replace bad bulb on left side,the bulbs have two elements in them.running lights on one and brake/turn signal on the other
ALLYDRIVER1 is offline   Reply With Quote
Old 09-05-2015, 10:46 PM   #3
superdrift's Avatar
This happened to me and the issue was a couple of old bulbs so try that first
superdrift is offline   Reply With Quote
Old 09-08-2015, 08:49 AM   #4
yogibooboorange's Avatar
Def sounds like a bulb issue. Just a note, when you install the sequential system, they will hyper flash if you don't change the flasher unit. The original flasher is set up for old bulbs and their resistance. LED bulbs have less resistance and will hyper flash without changing out the flasher with one made for the sequential system. And as an aside, you can probably go ahead and install the system and you will have no issues since your current troubles involves bad old style bulbs.
yogibooboorange is offline   Reply With Quote
Old 09-08-2015, 08:54 AM   #5
Most likely a jacked up bulb.
Also you don't need to change the flasher relay, that's just for the Raxiom kit. If you get the kit from the ppl who originally did the sequentials for 96+ cars you just splice and go or plug in and go.
Mustang Taillight Sequencers |Tail Light Sequencers | Sequential
Also the splice in slow rate kit is THE BEST ONE you can get and its like 1/4 the price of the Raxioms with the flasher relay. Instructions are almost idiot proof and splicing wires takes 5 minutes. Easy to put back to stock too with some solder and shrink tubing if that's something that is important.
Old 10-16-2015, 11:06 AM   #6
I checked the bulbs but they still work fine, so does that mean it is a sensor problem
66 Mustang taillight wiring problem mustangmatt_66 Classic Mustangs 3 08-18-2009 05:01 PM
Seq. Taillight Problem Mustang414 Pre-2005 V6 Mustang 7 04-17-2005 01:48 PM
taillight, or tail light covers..? vdog Mustang Audio & Video 5 03-19-2004 04:11 PM
Taillight Help McGrail482 Mustang Audio & Video 1 01-26-2004 08:01 PM
07:08 AM
