1995 3.8l waterpump - Mustang Evolution
Old 09-07-2015, 12:53 AM   #1
1995 3.8l waterpump
Hey Guys & Gals, so trying to change a waterpump on a 1995 3.8l. Cant get the powersteering pulley off(Tried the puller). heard you can take off the complete alt./powersteering bracket instead, to gain access to the waterpump? Any idea how many bolts there are? and where abouts? thanx in advance.
TroyB is offline   Reply With Quote
Old 09-12-2015, 12:24 AM   #2
wbrockstar's Avatar
Open the link below and follow the instructions.I believe one of the alternator bolts runs into the block and if you try to remove it,the ps pump pulley will be in the way and it doesnt leave enough room to get the bolt out far enough to remove the whole bracket assembly.However if you can extract every bolt that attaches the bracket assembly to the block,extract the alternator bolt I am referring to(if the ps pump pulley is not in the way)and remove the two nuts on the left side of that black brace(the one that goes from the water pump to the power steering pump)you should be able to remove the whole bracket assembly.
| Repair Guides | Engine Mechanical | Water Pump | AutoZone.com
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
wbrockstar is offline   Reply With Quote
Old 09-12-2015, 12:30 AM   #3
Thanx, I did it a couple days ago, without taking the power steering pump pulley off. If there's a will there's a way! Lol
Old 09-12-2015, 05:49 AM   #4
wbrockstar's Avatar
Its good to know it can be done without pulley removal.I can store the info in my memory bank to help the next person.Good job
91 LX 342ci(10.5:1)
TFS 190cc(stage ll)
TFS track heat
XE276HR .544" .544"
Flowtech 1 3/4"
Prochamber w FM
Waterpump gasket Beastynotch 1979-1995 Mustang GT 6 04-15-2012 10:01 PM
broke bolts for waterpump Robbie94gt 1979-1995 Mustang GT 5 11-24-2011 04:51 PM
Waterpump Bolts n screws! Ph23nom Pre-2005 V6 Mustang 0 02-17-2010 09:43 PM
1988 Mustang GT California Car Waterpump Mercedez L. 1979-1995 Mustang GT 4 01-26-2008 09:58 PM
waterpump gettin swapped out today Zim 1979-1995 Mustang GT 4 10-03-2005 07:29 PM
11:24 AM
