HELP - Mustang Evolution
Old 09-15-2015, 11:34 AM   #1
HELP
Hello I'm trying to install a new clutch kit in my 2000 3.8L mustang. I got every step done but I came to the step where you pull the transmission from the bell housing. I hot everything off ,the mount, the 4 Bolt's, the sensors , the drive shaft. I got it to separate from the bell housing a little bit but the input shaft seems like its stuck on something and the tyranny won't come out. Is the clutch fork holding it in?? Or do I have to have someone push the clutch in repeatedly and try to get it out????? Please help only car I have and suppose to start a new job and need the car.
mariedean265 is offline   Reply With Quote
Old 09-15-2015, 01:36 PM   #2
You did pull the shifter right?
The T5 should come apart from the bell without too much fuss. If you are sure you have EVERYTHING disconnected and only the input shaft being stuck is holding it in, use a pry bar and use leverage to get it the rest of the way out. Just be gentle.
Old 09-15-2015, 03:02 PM   #3
Yes did take the shifter off
Yes everything is off and disconnected and when I did pull the transmission out from the bell housing like 4 little balls fell out the bell housing. Is that from the tob?? That's why I'm putting a new clutch set in. Do I have to spin the input shaft to get it to release the transmission?????
Old 09-15-2015, 08:15 PM   #4
No it just pulls out. Any little balls that fall out are likely ball bearings from a destroyed throw out bearing.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 09-17-2015, 12:25 PM   #5
It's off
Got the transmission off the tob was stuck right to the shaft. Now 1 bolt on the bellhousing is totally striped and it's the only bolt left. Any ideas of how to get it off????
Old 09-17-2015, 03:54 PM   #6
Grind the head off and pull the bell then you should just be able to put some vise grips on it and spin it out.
Old 09-18-2015, 07:08 AM   #7
Is the 2000 v6 3.8L mustang internally or externally balanced
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 04:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 06:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 11:37 AM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 04:35 PM
04:21 PM
