Turbo - Mustang Evolution
Old 09-22-2015, 04:18 PM   #1
Yzfoxracer's Avatar
Turbo
I got a lot of questions about turbocharging my 3.8, first off a have a borg warner. I need to know how much it can handle stock and all the ins and outs what I need to upgrade and all the things I would need to complete the build
Sent from my SM-N910V using Mustang Evolution mobile app
Yzfoxracer is offline   Reply With Quote
Old 09-22-2015, 04:27 PM   #2
Rapinator126's Avatar
What size turbo do you have?
And are you planning on building a kit yourself or paying someone to fab one?
🍼and 🌽 fed coyote.
Old 09-22-2015, 04:32 PM   #3
Yzfoxracer's Avatar
55mm 5-15 psi building my self
Old 09-22-2015, 04:41 PM   #4
Experienced in welding aluminum?
It may be worth the cost of you are doing it 100% in house. But still won't be worth the power output your car can handle IMO.
T3 or t4 ?
Have you started looking at intercoolers?
Piping?
Waste gates ?
Blow off valves ?
Boost controllers if you plan on using one?
Thought about where your going to put 02's and wideband?
What size piping your going with for cold and hot side?
A lot of stuff you need to sit down and draw out first. Get a mental picture on how your going to build it.
Exhaust routing everything. Simplest way would be a front bumper exit.
🍼and 🌽 fed coyote.
Old 09-22-2015, 05:09 PM   #5
Yzfoxracer's Avatar
How much in ballpark do you think
Old 09-22-2015, 05:12 PM   #6
Depending on what brand stuff you go with, but considering you have the turbo.
2-4K in parts
🍼and 🌽 fed coyote.
Old 09-22-2015, 05:15 PM   #7
But that's the easy part.
Building one that works properly will be the tricky part.
You have to make sure everything is correct. Poor piping size or restrictive bends and or to many bends in the piping, can lead to excessive back pressure build up with a turbo. Which in turn can lift a head.
🍼and 🌽 fed coyote.
Old 09-22-2015, 05:16 PM   #8
Turbo
Like I said earlier first get a mental picture in your head on how you will build it.
Look at JPC for all your parts you will need they have it all. Good prices also.
🍼and 🌽 fed coyote.
Old 09-22-2015, 08:43 PM   #9
1slosix's Avatar
on moddedmustangs there is a guy that did a full write up im pretty sure as he did his turbo install. never hurts to check out a fellow site to see if it can help answer some of your questions. im not sure if anyone on here has done a write up yet
carving corners like a boss
Old 09-22-2015, 08:46 PM   #10
Yzfoxracer's Avatar
Do you know his name
Old 09-22-2015, 09:07 PM   #11
1slosix's Avatar
no but he posts in almost every thread in the v6 section and on the what tech did you do thread he just posted about his custom radiator fan shroud so he is easy to find
Old 09-22-2015, 09:10 PM   #12
Yzfoxracer's Avatar
Ok thanks for the help for now guys gotta think long and hard
VORTECH SUPERCHARGER, LPF TURBO (Or Any Turbo) Or, PROCHARGER? 2FlyGraffiti 2015+ Mustang Ecoboost (and V6) 8 06-22-2015 01:45 PM
turbo 3.8 v6 or swap to (turbo??) 4v dohc 4.6 v8??? morthis32 Pre-2005 V6 Mustang 95 09-07-2012 03:27 PM
Can I get a twin turbo kit to work on a newer model a mustang than what the turbo kit was made for? warrane General Mustang Discussion 4 04-08-2010 11:09 AM
Super and Turbo chargers together. Horse Pre-2005 V6 Mustang 13 12-21-2003 10:37 PM
I got some Dynomax Thrush Turbo Mufflers fast64 Pre-2005 V6 Mustang 4 07-25-2003 05:18 PM
08:11 AM
