Belt noise - Mustang Evolution
Old 10-05-2015, 03:50 PM   #1
Belt noise
I have loud squeal at start up but as soon as i turn the ac it stops. I just replaced the tensioner, belt, and idler pulley. Can i tighten the tensioner or what should i do?
Sent from my LG-D851 using Mustang Evolution mobile app
Old 10-06-2015, 07:18 AM   #2
yogibooboorange's Avatar
" have loud squeal at start up but as soon as i turn the ac it stops" Does this mean you turn it on or does this mean turn off the AC? The AC clutch is supposed to free wheel when not engaged. It just may be possible the clutch is stuck and only allows the clutch to turn when turned on. Have someone watch as you turn it on and off. Also, does the squeal return when you do either on of off?
yogibooboorange is offline   Reply With Quote
Old 10-06-2015, 09:49 AM   #3
Yea when i turn on the ac it stops and if i turn it off it will start to squeal again unless its at operating temperature
Old 10-12-2015, 03:32 PM   #4
Don't make sence, squeal stops with more load? Replace belt and tensioner
ALLYDRIVER1 is offline   Reply With Quote
Old 10-12-2015, 05:56 PM   #5
I'll replace the belt first since the tensioner was a p.i.a. they're both dayco brand not oem if that matters
5.0, belt route and belt length question. Hatenot SVT Mustang 3 04-04-2014 09:12 AM
Belt Noise BlackSmoke02 Pre-2005 V6 Mustang 21 05-27-2013 10:40 AM
2001 v6 3.8 engine noise after new belt truckdriver0 Pre-2005 V6 Mustang 6 01-03-2013 09:03 PM
engine making belt noise engine ticking sounds like a diesel 3k miles on car Yellow50 2011-2014 Mustang GT 34 05-04-2012 09:56 AM
sounds like a belt but... not a belt!! vwdavid Pre-2005 V6 Mustang 4 09-03-2010 10:29 PM
07:06 PM
