HELP!!!! - Mustang Evolution
Old 10-05-2015, 04:34 PM   #1
Feather_Not_Dot's Avatar
HELP!!!!
So my 02 3.8 threw 2 codes on me today, system too lean bank 1 and system too lean bank 2. I've cut the exhaust off behind the Y so it still has the cats. I've already replaced the exhaust manifold.
2002 3.8l v6 automatic
Feather_Not_Dot is offline   Reply With Quote
Old 10-06-2015, 07:13 AM   #2
yogibooboorange's Avatar
Did you disturb the 02sensors or their wiring when cutting? Just a thought!
yogibooboorange is offline   Reply With Quote
Old 10-06-2015, 09:49 PM   #3
1slosix's Avatar
could be a list of things for a lean code. although i don't think it's your new exhaust unless you messed up an upper sensor when you changed the manifolds out. Can you give us details on how it's acting besides the codes?
carving corners like a boss
Old 10-12-2015, 09:46 PM   #4
2000v6stang's Avatar
Region: Iowa
02 sensors, vacuum leak, air coming in after the MAF sensor
MAC long tube headers, pypes o/r H pipe, MAC catback, SR cold air intake, Performance Automatic shift kit, blacking out
Blacking it out, MAC duel exhaust, SR CAI, Performance Automatic shift kit. And a long build list wrecked in July '14
2000v6stang is online now   Reply With Quote
Old 11-13-2015, 07:34 PM   #5
I agree with 2000v6stang. 02 would be my first stop. Whens the last time you cleaned your MAF?
one day i hope to have something pretty damn witty here
jake01roushv6 is offline   Reply With Quote
Old 11-17-2015, 12:03 AM   #6
Jmustang78's Avatar
Region: Montana
Send a message via Yahoo to Jmustang78
Check the ducting from air box to throttle body. If there is an air leak or crack anywhere or the map sensors or O2's r unplugged? Aside from that I'd check on replacing O2 sensors
Jmustang78 is offline   Reply With Quote
Old 11-17-2015, 05:31 PM   #7
Whats the voltage coming from the o2 sensors
ALLYDRIVER1 is offline   Reply With Quote
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 04:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 06:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 11:37 AM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 04:35 PM
12:11 PM
