A/C Problem - Mustang Evolution
Old 11-26-2015, 10:30 PM   #1
JudenInduven's Avatar
Question A/C Problem
The heat in my '01 V6 doesn't work seemingly at all. The actual cool air works perfectly, but the heat (even at the highest heat setting) blows ~65 degree air when at engine operating temperatures. With winter approaching, the outside temperature being around 10 degrees, the fact that I park my car outside, and now the fact that I find the heater doesn't work makes me really dread driving the Mustang
I would think the heat not working would be impossible, seeing as the engine gets really hot (relative to typical things) while in use , and I thought the heat for the a/c got drawn from the engine (but I don't know for sure, so don't quote me on that)
I tried looking up if anyone has had a similar problem and couldn't find anything, so I'm turning to you guys
Thanks
JudenInduven is offline   Reply With Quote
Old 11-27-2015, 07:22 AM   #2
yogibooboorange's Avatar
Sounds as though your heater core is plugged up. My first question is this: is your car running at normal temp or is it fluctuating or running hot. Your thermostat may be the culprit, not opening fully when running temp is reached. I would start there. Also, your hot/cold settings are vacuum controlled I believe. The vacuum control may be malfunctioning. Lots of variables here to check out.
yogibooboorange is offline   Reply With Quote
Old 11-27-2015, 07:27 AM   #3
dave73's Avatar
Before you go crazy you don't have any coolant leaks do you?
dave73 is offline   Reply With Quote
Old 11-27-2015, 10:03 AM   #4
-Yeah, system needs to be bled of air and definitely verified that it is full. Remove air bleed plug, squeeze hoses, watch it as it's on and circulating through the bleed plug hole.
I would flush it with water only & keep checking/recording the heat temperature as water is flushing out system & circulating.
Once a chemical cleaner is added, it is a bear to completely clean it out for fresh fluid.
-94-04 V6 needs to have a thermostat with a bleed hole in it set at 12:00, towards the firewall.
Old 11-27-2015, 12:12 PM   #5
Nope, no coolant leaks
The car's temperature is entirely steady. And those all sound like quite possible solutions to me
Definitely sounds like a plan.
Thanks for all the help guys, it gives me some good starting points for this
Old 11-28-2015, 12:19 AM   #6
gqsmash's Avatar
Just to add another option...the blend door could not be going to full heat. My brother had that issue before
gqsmash is offline   Reply With Quote
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
Squeeling problem Sil\/erSpeed Pre-2005 V6 Mustang 3 08-17-2003 04:24 PM
News update on engine problem Danger Dude Pre-2005 V6 Mustang 14 08-11-2003 01:54 PM
Major Wiseco Piston PROBLEM! *DUW** plstktnkr2 Pre-2005 V6 Mustang 3 07-21-2003 02:58 PM
01:04 AM
