Grinding When Shifting? - Mustang Evolution
Old 11-30-2015, 09:18 AM   #1
JudenInduven's Avatar
Hey all,
So, sometimes when I stop and shift into first, the shift knob kind of kicks back in my hand, grinds, and refuses to go in. Usually, if I move it to neutral and then back it's just fine. Same thing happens going into second, third, and fifth occasionally.
The only thing I can think of is that my clutch (which is probably going to go out in 300-400 miles) isn't engaging all the way or something. I always push the clutch all the way in, though. Could a misalignment of the shift knob going into a gear cause this horrendous grinding noise?
JudenInduven is offline   Reply With Quote
Old 11-30-2015, 09:53 AM   #2
Could be an issue with the clutch, the cable might not be tight enough or the trans itself is shot. I would not keep on grinding away if the issue is not the trans itself tho or it quickly will become an issue.
Old 11-30-2015, 11:17 AM   #3
I really hope it's the clutch. My mechanic said it did look pretty bad, but could last me until the end of the year, tops. Right now I only have to depress the clutch pedal maybe 3-5 inches to be able to shift, or probably about 1/5 of the clutch's arc.
I'll go to the mechanic tomorrow, since I noticed this a month or two ago but didn't think anything of it. Thanks for the info
Old 12-01-2015, 06:36 AM   #4
If you are grinding it every time you shift the clutch needs to get done asap and hope you didn't bork the synchros.
Old 12-01-2015, 10:10 AM   #5
It's not nearly every time I shift. Maybe one out of every 40 times going into 1st or 5th, about once a day or slightly less. The reason it grinds going into 2nd or 3rd is my own fault I realize. The only time I've heard those grind is when I missed a shift
The chargers are slugs lol
2001 3.8L - Cheap SR CAI, SF4/X4 w/ 91 Octane Bama Tuning, Pacesetter H-pipe and Borla Stingers, Auburn HP Limited-Slip Diff, FRPP 4.10 gears
Coming EVENTUALLY: BBK headers, Eibach Springs, FRPP Aluminum Driveshaft, Maximum Motorsports Caster Camber Plates
Power Shifting vs Quick Shifting BlueDemon 2011-2014 Mustang GT 10 06-02-2016 09:50 AM
grinding when shifting into 3rd phillip433 Mustang DIY and Technical 0 07-25-2014 03:15 PM
Grinding when shifting--what is it SunCity85373 1996-2004 Mustang GT 8 01-06-2011 04:21 PM
grinding noise from diff. Horse Pre-2005 V6 Mustang 8 04-27-2004 04:47 PM
grinding sound, stiff breaks, and loos of power wile driving blk2kconvstang Pre-2005 V6 Mustang 4 04-05-2004 07:20 AM
02:47 AM
