Mach 1 trans and rear end - Mustang Evolution
Old 11-30-2015, 09:05 PM   #1
superdrift's Avatar
Since im parting the mach out im thinking i should put it on the v6 and eventually swap the motor, question is will it bolt up to my 99 v6 motor?
superdrift is offline   Reply With Quote
Old 12-01-2015, 01:27 PM   #2
JudenInduven's Avatar
[/COLOR]
What parts, specifically? Driveshaft? LSD?
The chargers are slugs lol
2001 3.8L - Cheap SR CAI, SF4/X4 w/ 91 Octane Bama Tuning, Pacesetter H-pipe and Borla Stingers, Auburn HP Limited-Slip Diff, FRPP 4.10 gears
Coming EVENTUALLY: BBK headers, Eibach Springs, FRPP Aluminum Driveshaft, Maximum Motorsports Caster Camber Plates
JudenInduven is offline   Reply With Quote
Old 12-01-2015, 02:26 PM   #3
superdrift's Avatar
Originally Posted by JudenInduven View Post
[/COLOR]
Whatever will make the v6 a stick and do a 2 wheel burnout lol
Old 12-01-2015, 02:37 PM   #4
You're trying to convert your auto to a stick? I honestly have no knowledge on the subject and can't help you there.
As far as the two-wheel burnouts go, you'll need a limited slip differential to replace the stock open diff. But, the limited slip on the Mach 1 is 31 spline, which won't fit your sixxer's stock driveshaft (which is 26 spline), and you'd need to buy one that's 26 spline. Unless you want to also take the heavier 8.8" driveshaft from the Mach 1, but I believe you sacrifice a bit of acceleration from it, though it can withstand higher HP/TQ ratings, in case you were also planning on forced induction at some point.
I'd say, if you have the money, get the 8.8" driveshaft, the 31 spline LSD off the Mach
Old 12-01-2015, 04:17 PM   #5
superdrift's Avatar
I was just thinking why not turn a bad situation into a good one, but now that looks like it wont be so plug and play
Old 12-01-2015, 05:04 PM   #6
No, especially not the limited slip. You'd have to take out the the whole differential and move the ring and pinion gears out from the old diff to the new one and re-oil it all. For the job, my mechanic quoted me 700 dollars Of course, you'll hear of other people getting it done for 400-500, but every shop in my town has wanted upwards of six or seven hundred. As for the driveshaft swap, I think it's another couple hundred maybe two or three
Old 12-01-2015, 07:32 PM   #7
superdrift's Avatar
Well forget that then, i guess i will sell it and get a bullitt
Old 12-01-2015, 07:49 PM   #8
fwalck's Avatar
Ypu can take the whole rear out of the Mach and put in place of the rear on the v6 with no modifications
fwalck is offline   Reply With Quote
Old 12-01-2015, 08:38 PM   #9
But he doesn't want to pay for the whole new install, since it won't be exactly bolt-on. If he took out the whole rear end, it'd be easier, but still costly, right?
Old 12-01-2015, 09:23 PM   #10
fwalck's Avatar
No you can unbolt the drive shaft the speed sensors brakes and the 4 control arms and everything will switch right over between the 2 cars
Old 12-01-2015, 09:49 PM   #11
Well, live and learn, eh? I thought he just wanted the LSD and the trans swap. No clue how to do a trans swap though
Old 12-01-2015, 11:33 PM   #12
The 3.8 and the 4.6 transmissions are not interchangeable.
The rear end, however, will bolt right up. And the front brakes will bolt right up as well.
Old 12-08-2015, 10:34 PM   #13
Also the factory SRA in the Machs are 28 spline just like the GT's. They are not 31 spline so it will bolt right up with no modifications.
The 3650 will not simply bolt in however.
Read end and trans re-sell price GT1995 1979-1995 Mustang GT 2 08-06-2015 10:16 AM
mach 1 rear end swap to my v6 97V6stangct Pre-2005 V6 Mustang 4 01-20-2012 09:02 PM
how much hp can a stock trans and rear end handle kalell420 1996-2004 Mustang GT 4 09-27-2011 09:19 AM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 04:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 07:56 PM
12:09 AM
