Basic Knowledge? - Mustang Evolution
Old 12-05-2015, 09:29 PM   #1
JudenInduven's Avatar
Basic Knowledge?
So, on AM's install guide for the Borla Stingers it mentions to not use air impact tools to tighten the fasteners on the system. That's mentioned for the DIY-er's benefit, right?
For a lot of things I've read like that, I wonder if my mechanic knows that. Is it basic knowledge that he should have for the install of it, or should I mention it to him? He's a master certified ASE technician. I think that's his title.
Same goes for the fact that my H-pipe says to cut the stock midpipe at a certain point so it reuses the stock cats and the exhaust system hangs correctly.
Thanks for the help
The chargers are slugs lol
2001 3.8L - Cheap SR CAI, SF4/X4 w/ 91 Octane Bama Tuning, Pacesetter H-pipe and Borla Stingers, Auburn HP Limited-Slip Diff, FRPP 4.10 gears
Coming EVENTUALLY: BBK headers, Eibach Springs, FRPP Aluminum Driveshaft, Maximum Motorsports Caster Camber Plates
JudenInduven is offline   Reply With Quote
Old 12-05-2015, 09:42 PM   #2
Used air tools on mine, zero issues.
Pick your poison.
Old 12-05-2015, 09:47 PM   #3
Pick your poison.
Right, but that's all things a mechanic should know by default, right, where to cut the stock Y-pipe to preserve and reuse the cats and such?
Old 12-05-2015, 10:13 PM   #4
natestang07's Avatar
It all depends on how often they work on certain things.
Old 12-05-2015, 10:14 PM   #5
Hmm...fair enough. I'll just be sure to mention some of those things in passing to him then, just to be sure. I don't want to be condescending though
Old 12-05-2015, 11:12 PM   #6
Yeah just point some things out just to be safe. I get what you are saying about being condescending though
Old 12-06-2015, 06:17 AM   #7
Strange Mud's Avatar
I would not mention something like that......he knows (assume) if he uses air to be careful and the only bad part would be breaking the clamp which he would replace. I would instead mention "w/o insulting I do expect the tips to be aligned" I will say printing up install sheets and leaving them in car as hints ain't bad...assuming he can read.
the few times I've brought my car in for wtty service I leave a note mention reverse is hard to get into and to respect my car.
more HP, basic mods for 2000 GT sparkylarue 1996-2004 Mustang GT 4 02-17-2008 10:44 PM
basic info on turbos I_luv_HP&trq Pre-2005 V6 Mustang 7 10-25-2005 11:34 AM
Visual Basic .NET Brent The Bar 2 04-12-2004 06:22 PM
Stock MACH deck output power/Basic amplifier question DropTop_Stang Mustang Audio & Video 0 08-10-2003 11:00 PM
11:24 PM
