Concerning Noise - Mustang Evolution
Old 12-10-2015, 01:02 AM   #1
JudenInduven's Avatar
Concerning Noise
So, I just had my much-anticipated Borla's installed ( ) and now at ignition, I sometimes hear a knock or "pop" kind of noise from various parts of the undercarriage. I've heard it in the passenger side back, center back, and basically right under where I sit. I've only started the car since the new exhaust maybe 7 times.
No idea what it is.
It kind of sounds like, if you've ever heard it, on the engine deceleration with dual exhausts the kind of slight popping noise from the exhaust. Here's a video of a Mustang with a similar exhaust set-up as mine to help explain better: https://youtu.be/CtPMVC3wubY?t=59s At about the 1 minute mark, you hear the sound.
This, paired with the fact that my car was refusing to be refueled today are both kind of worrying me. I put in the nozzle and it was filling up the thousandths of a gallon extremely slowly. Then I went to a different station and tried to fuel up and it just went for about a third of a second and clanked off like it was full. Tried one more time and it fueled up without a hitch.
Sorry to make that so long, but there are a lot of things I think might be important details
The chargers are slugs lol
2001 3.8L - Cheap SR CAI, SF4/X4 w/ 91 Octane Bama Tuning, Pacesetter H-pipe and Borla Stingers, Auburn HP Limited-Slip Diff, FRPP 4.10 gears
Coming EVENTUALLY: BBK headers, Eibach Springs, FRPP Aluminum Driveshaft, Maximum Motorsports Caster Camber Plates
JudenInduven is offline   Reply With Quote
Old 12-10-2015, 01:35 AM   #2
Mile high JDF's Avatar
If it's a pop like in the video then that is completely normal. Most exhaust systems will do that.
Sent from my SM-G925V using Mustang Evolution mobile app
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-10-2015, 09:48 AM   #3
It's like the pop in the video, but louder, at ignition and occasionally acceleration, and it sounds more sudden and jarring. I'll keep an ear out for the next time I hear it and see if it just sounds like the exhaust doing its thing
Old 12-10-2015, 10:12 AM   #4
natestang07's Avatar
My outlaws would always give one loud pop right after I started my car on a cold start. If you can get a video im sure we could tell you if it was normal
Old 12-10-2015, 10:24 AM   #5
Unfortunately, I can't get a high enough quality video to really demonstrate it, but a loud pop right after startup on a cold engine does sound like what I'm talking about
Old 12-10-2015, 10:59 AM   #6
Yeah it is normal and nothing to worry about if that is the case.
Old 12-10-2015, 11:04 AM   #7
Cool, thanks for the info! Now I can enjoy the Stingers without worrying about noises and whatnot
Old 12-10-2015, 06:44 PM   #8
+1^ you should have heard my vette...
Old 12-10-2015, 08:44 PM   #9
That little pop was the thing I liked about my outlaws. My uncles Zo6 has a pretty gnarly pop to it as well.
Old 12-10-2015, 09:12 PM   #10
LS motors crackle so much, it made going back to my Bullitt quite a disappointment
Old 12-16-2015, 05:41 AM   #11
mattyp511's Avatar
Region: New Mexico
Could be a fouled plug... Check them incase
Sent from my LG-D801 using Mustang Evolution mobile app
mattyp511 is offline   Reply With Quote
Old 12-16-2015, 11:01 AM   #12
What part of the system would that be and how would I check it?
Old 12-16-2015, 06:55 PM   #13
He's talking about spark plugs. Basically pull your spark plug wire off and remove your spark plug to see if there are any unusual colors to it.
Old 12-17-2015, 02:23 AM   #14
Oh, duh. I thought he meant an O2 sensor plug or something. I'll be sure to look at it. I also have an occasional kind of clank...but I'll try to describe it later because I can't remember it. I just got back from having my car stuck, perpendicular to the road for two hours. All I can hear in my head is my tires screeching from trying to reverse to no avail.
Old 12-17-2015, 05:31 AM   #15
Nope, just the spark plugs.
It's probably an exhaust pipe bumping the body. It's pretty common on exhaust installs.
Are your tires that bald? I've always had good luck with rocking the car back and forth to build some momentum to get out of a rut. Or you can just carry some kitty litter with you in the trunk.
Old 12-17-2015, 10:18 AM   #16
Good to know for the exhaust pipe.
And, nope, the tires are new. 240lbs of sand on the rear axle, had kitty litter behind the wheels, couldn't move forward at all. I eventually got out by revving it to 3000 and dropping the clutch in reverse. That moved me back a few feet, then I ultimately just drove up onto the curb and out from there
concerning breathers kit on my stang nosympathy 2011-2014 Mustang GT 29 06-06-2013 12:54 AM
Question concerning Wheel Rub 88gtCc 1979-1995 Mustang GT 6 01-12-2012 01:52 PM
Concerning a manual v8. Patrick General Mustang Discussion 20 05-10-2011 09:25 AM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
Great Article about the "Spectators" in Eurpope concerning Iraq Brent The Bar 1 11-06-2004 02:34 PM
12:17 PM
