Rough idling - Mustang Evolution
Old 12-19-2015, 04:27 PM   #1
Rough idling
I took off my intake manifold and valve covers to paint them the same color as the car. I cleaned out everything but my dad cleaned out the throttle body, not seeing the DO NOT CLEAN on it lol. All that was used was gas and a brush. At first the vacuum hoses weren't right but now are all right but the car will not idle. It will turn over and rev up to 3k and back down. After revving It for a few minutes it will idle around 500-700 and is super lumpy. Does anyone know what I have to do to fix this? Do I just need to buy a new IAC?
98stang6banger is offline   Reply With Quote
Old 01-20-2016, 08:01 PM   #2
ascottg96's Avatar
you could have a leak in the vacuum now. If it wasn't having this problem before its most likely something with what you messed with. The gas maybe could have done some damage to the hoses. Also clean the MAP sensor, sometimes if that gets dirty it can cause a rough idle. maybe some dirt could have got in the cold air intake as you had the throttle body off and the intake manifold off.
ascottg96 is offline   Reply With Quote
Old 01-20-2016, 08:23 PM   #3
Senior Member
rlma84's Avatar
This happened to my dodge charger after cleaning throttle body and without knowing that I wasn't suppose to move the butterfly flap manually but after few miles of ruff iddle driving it went away the rpms where all over the place also
Sent from my SAMSUNG-SM-N920A using Tapatalk
rlma84 is offline   Reply With Quote
Old 01-20-2016, 08:26 PM   #4
Senior Member
rlma84's Avatar
BTW here is what mine looked like (I know pretty bad)
Old 01-21-2016, 07:46 AM   #5
Thanks to everyone to commented. I figured it all out. Somehow I got upper intake manifold gasket bent down to where it was in the intake slot going into the cylinder. I put a new gasket on and now it's running perfectly fine
Car idling rough p2195 and p2197 hdez41 2011-2014 Mustang GT 63 08-30-2015 01:21 PM
Rough idling Xaperez100 Pre-2005 V6 Mustang 7 02-11-2013 05:48 PM
Rough Idling greenmustang27 Pre-2005 V6 Mustang 2 05-14-2009 09:29 AM
Help Needed In England - Idling Problem glenheyes 2005-2010 Mustang GT 11 04-21-2008 04:08 PM
Rough Idle and Rough Start Cajun JungleBoy Pre-2005 V6 Mustang 3 04-23-2006 11:33 PM
04:44 AM
