Problem With Sequential Taillight Kit - Mustang Evolution
Old 01-03-2016, 03:23 PM   #1
I received a sequential kit for my 04 for Christmas, and installed it with no problems. The kit worked the first night I had it. Now, it works almost as it should, but the bulb closest to the outside of the car blinks twice: in the sequence and again with the middle bulb (of the housing). Is this an issue with the kit itself, or a wiring problem?
o4v6 is offline   Reply With Quote
Old 01-03-2016, 11:20 PM   #2
1slosix's Avatar
sounds like a kit issue in the wiring order. did you replace the flasher as well with a sequential rated flasher?
carving corners like a boss
Old 01-04-2016, 06:58 AM   #3
yogibooboorange's Avatar
Who manufactured the kit? I would call them and let them advise what to do here.
yogibooboorange is offline   Reply With Quote
Old 01-04-2016, 07:34 AM   #4
If its the Raxiom send it back for a new one, PM an AM rep on here and you should get a RMA setup real quick.
This is another issue I have heard of with the Raxiom setup failing if it is indeed the Raxiom setup btw. There is a better kit out there for $65.
Old 01-04-2016, 02:05 PM   #5
I did not replace the bulb at all, I followed the instructions with the kit and they did not say to do that. The brand of the kit is called GT Concepts, if that would help.
Old 01-04-2016, 03:14 PM   #6
Hellish Horse's Avatar
The Flasher he's talking about is the one that plugs into the fuse box. It slows down the order of the blinking so they look right. Otherwise they blink too fast. I had to do that with my 04. Never had them blink out of order or twice though. Are you sure you put the right wire harness on each side? They only work one way.
Hellish Horse is offline   Reply With Quote
Old 01-05-2016, 06:59 AM   #7
GT Concepts warranties the units for life so I would talk with them regarding your problem. They will fix or replace the product. Keep us informed as to what transpires. I wish to get a unit for my 2002 vert !
Old 01-05-2016, 07:04 AM   #8
If they have a warranty then definitely get in contact with them and get a new kit.
Sequential tail light kit problem C_Dailey95 2005-2010 Mustang GT 26 06-10-2016 07:02 PM
Left Taillight problem Rubenfran26 Pre-2005 V6 Mustang 5 10-16-2015 11:06 AM
66 Mustang taillight wiring problem mustangmatt_66 Classic Mustangs 3 08-18-2009 05:01 PM
Seq. Taillight Problem Mustang414 Pre-2005 V6 Mustang 7 04-17-2005 01:48 PM
Sequential Taillight Group Buy drummerstang98 Mustang Parts for Sale and Wanted 97 04-14-2005 05:12 PM
03:24 AM
