How much improvement? - Mustang Evolution
Old 01-07-2016, 12:13 PM   #1
JudenInduven's Avatar
So, in theory, an aluminum driveshaft and flywheel would be less rotating mass, and thus, the car would accelerate faster. My question is: how much does it actually help? Would a 0-60 pull be noticeably faster, or should I not waste the total 700 dollars it would cost me?
Also, how does less rotating mass help the engine accelerate? Would it just lose a lot of potential force from it weighing less, allowing the engine to get everything going quicker?
(Oh, and if someone has a link to the thread another member was talking about regarding ET's and its relation to ring and pinion gearing, I'd appreciate it)
The chargers are slugs lol
2001 3.8L - Cheap SR CAI, SF4/X4 w/ 91 Octane Bama Tuning, Pacesetter H-pipe and Borla Stingers, Auburn HP Limited-Slip Diff, FRPP 4.10 gears
Coming EVENTUALLY: BBK headers, Eibach Springs, FRPP Aluminum Driveshaft, Maximum Motorsports Caster Camber Plates
JudenInduven is offline   Reply With Quote
Old 01-08-2016, 08:18 AM   #2
Mile high JDF's Avatar
Here's your link. The truth about gears..
I do have an aluminum driveshaft in mine but can't say what the difference is because I bought it that way. When engine braking it is definitely very different from my old GT.
The theory behind lighter drive train components is that they reduce rotating mass, which in turn means the engine uses less power to try and rotate everytjing. Swapping to them should help increase the speed at which your engine goes through the RPM range. It's similar to U/D Pullies in the way that it's essentially freeing up some power that was previously used to get everything moving.
Personally I wouldn't waste the money unless you don't have any other beneficial mods you want to do and have extra cash laying around.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-08-2016, 09:13 AM   #3
Here's your link. The truth about gears.. - Mustang Evolution
The theory behind lighter drive train components is that they reduce rotating mass, which in turn means the engine uses less power to try and rotate everything. Swapping to them should help increase the speed at which your engine goes through the RPM range. It's similar to U/D Pullies in the way that it's essentially freeing up some power that was previously used to get everything moving.
Thanks for the info on that, and for the link. I figure, I do have to replace my clutch, so I may as well throw an aluminum flywheel on at the same time, and I need a limited-slip diff, so may as well throw some gears in
Old 01-08-2016, 11:13 AM   #4
Fair enough. Good luck with either route
Old 01-08-2016, 11:28 AM   #5
Sterlingbeast5.0's Avatar
quick FYI, check with others but if might boost dont do the aluminum instead go for lightened steel
Old 01-08-2016, 12:28 PM   #6
Thanks, but I likely will not do FI or Nitrous, just because of the associated cost with it. Full bolt-ons are probably the most I'll go, if even
Here is MORE improvement for the MT82! Deerslayer 2011-2014 Mustang GT 94 04-02-2015 12:10 PM
Is there a good bit of improvement in acceleration going from 2.73 to 3.31 gears ??? GT 1 2011-2014 V6 Mustang 11 07-09-2014 08:08 PM
App improvement Quball19 ME Site Help & Announcements 33 05-31-2012 10:42 PM
2000 v6 acceleration n speed improvement? CHILE10_STANG Pre-2005 V6 Mustang 5 07-12-2009 10:41 PM
Steering Rack improvement(s)/ Vibration cure(s) jimbullit 2005-2010 Mustang GT 2 05-06-2009 11:43 AM
12:12 AM
