Car won't fire up - Mustang Evolution
Old 01-21-2016, 10:11 AM   #1
bkh1994's Avatar
Car won't fire up
So my car has been sitting for a few months. I tried to crank it and it wouldn't fire up. The engine turns and the starter is working but it won't fire up. I got it running once and then as soon as I revved it a little (to try to keep it running) it shut off. I've added a few gallons of gas to it. I've swapped batteries. I've added coolant and engine oil. What else could it be?
bkh1994 is offline   Reply With Quote
Old 01-22-2016, 08:32 AM   #2
Mile high JDF's Avatar
I would take a look at your fuel pressure. Sounds like the pump is going out.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-22-2016, 03:56 PM   #3
bkh1994's Avatar
I just took the fuel filter out. I'm sure it wasn't helping. Out of one side it looked about as dark as oil coming out. Then the other side had plain gas coming out
Old 01-22-2016, 08:00 PM   #4
Definitely change it. That could very well be your problem
Old 01-23-2016, 03:17 PM   #5
bkh1994's Avatar
Got a clean fuel filter put in and it's still not firing up. I'm going to check on the spark plugs and wires then go from there
Sent from my SPH-L710 using Mustang Evolution mobile app
Old 01-23-2016, 05:44 PM   #6
ascottg96's Avatar
Was it stored inside? Or just outside? Maybe an animal could've chewed a wire to something causing it to not start
ascottg96 is offline   Reply With Quote
82 5.0 won't fire Wombatnation 1979-1995 Mustang GT 2 09-13-2015 02:37 PM
2000 V-6 Cranks but won't fire jbow Pre-2005 V6 Mustang 2 12-25-2014 10:21 AM
Dashes across odometer, car won't fire up - Not looking good. V6 stang Pre-2005 V6 Mustang 9 07-29-2012 10:59 PM
68 coupe 289 lights come on but won't turn over and headlights won't come on Sixty8 Coupe Classic Mustangs 2 03-07-2009 08:52 PM
05:42 AM
