!Help! Engine Idling and Rev Issues - Mustang Evolution
Old 08-08-2008, 12:32 AM   #1
Unhappy !Help! Engine Idling and Rev Issues
Hey guys, i know I'm new to the forums but hopefully some one can help me. Two days ago i took my car into the Ford dealership because my car will jump up anywhere from 1,000-2,000 rpm when i put the clutch in, sometimes it will even jump up and then die. Ford blames it on my k&n aftermarket cold air intake, however i called k&n and they said that the cold air intake could not be the problem!? Confused as ever and still stuck with the problem, i turn to you all. Please help!
06v6stang is offline   Reply With Quote
Old 08-08-2008, 04:24 AM   #2
Scorpion1's Avatar
Re: !Help! Engine Idling and Rev Issues
Sounds like a possible MAF issue. Did you install the intake? Connector may not be in correctly/dirty or MAF could be bad. This is just a suggestion as I am fairly new to these cars as well so Id wait for a second opinion.
WiCK3D_SiX
Scorpion1 is offline   Reply With Quote
Old 08-08-2008, 06:22 AM   #3
I'm willing to gamble if you take the intake off and put the stock one back on it won't do that...or just get a tune, one of the two.
Old 08-08-2008, 06:34 AM   #4
first off clean the MAF sensor, especially if you have re-oiled that K&N filter. It gets crap on it and gets nasty from the oil in the K&N. Its easy to clean you just use on contact NO residue electrical parts cleaner. Clean it good.
The second thing is replace the IAC valve (idle bypass valve) that controls idle of the car in neutral.
After that remove the negative battery cable for a bit and hit the brakes a couple times to drain the power out of the system then put it back on. This may fix it~ if not come back and post here.
If all of the above doesnt work try the stock intake~ as said above.
Old 08-08-2008, 06:46 AM   #5
Herbstang's Avatar
What Brandon And Brad said !!! also check for a vacuum leak by the breather hose that connects the intake tube .there may also be a second hole with a gromit in the tube for an air temp sensor. check that
Old 08-08-2008, 07:12 AM   #6
Hey guys thanks for all the input, ill give all those things a check today and over the next few days. Ill re post if those things don't work. Thanks a bunch for the quick response!
Idling too low katie_ann 1996-2004 Mustang GT 9 09-02-2009 03:42 PM
Rough Idling greenmustang27 Pre-2005 V6 Mustang 2 05-14-2009 08:29 AM
engine issues... no codes... fuel pump video added jimmy_beaner 1996-2004 Mustang GT 99 05-02-2009 11:56 AM
Help Needed In England - Idling Problem glenheyes 2005-2010 Mustang GT 11 04-21-2008 03:08 PM
94 rev limit sledgehammer Pre-2005 V6 Mustang 4 03-03-2008 09:16 PM
10:46 AM
