Removing stud from exhaust flange - Mustang Evolution
Old 01-24-2016, 07:25 PM   #1
Iryan7's Avatar
Sorry if this has been covered, trying to finish this manifold tonight. The manifold I'm putting on is missing a stud from the flange. I planned on removing one from my broke header, but I can't seem to find a way to get it out. If anyone knows a way to get this off I would appreciate it. Thanks!
Sent from my SM-G920T using Mustang Evolution mobile app
Iryan7 is offline   Reply With Quote
Old 01-24-2016, 09:12 PM   #2
oxfordwhite's Avatar
Did you try the double nut trick? Put two nuts on, tighten together, then back whole unit out with bottom nut. A little heat on flange wont hurt. Good luck
oxfordwhite is offline   Reply With Quote
Old 01-25-2016, 08:59 AM   #3
Bravebowhunter's Avatar
Heat is your best friend right now! Get a torch on it till it turns red.
Bravebowhunter is offline   Reply With Quote
Old 01-28-2016, 06:39 AM   #4
yogibooboorange's Avatar
+1 for both ideas on heat and the double nut. Apply penetrating rust buster liberally a few hours before you heat and loosen. It will come free. Also, tighten first before trying to loosen. Helps break up the rust. Work it back and forth a little at a time until it breaks free. Good luck.
yogibooboorange is offline   Reply With Quote
exhaust
2013 cat converter flange nut dudley279 2011-2014 Mustang GT 0 08-10-2014 01:58 PM
Exhaust flange gasket 1996v6stang 1996-2004 Mustang GT 11 01-12-2013 04:57 PM
anyone know where to buy exhaust flange's? rebeltx 2011-2014 V6 Mustang 15 10-26-2012 06:09 AM
Exhaust manifold flange bolts jwhayne0001 1979-1995 Mustang GT 14 12-30-2011 05:49 AM
01 GT mufflers from H pipe flange back. No tailpipes Player Pony Mustang Parts for Sale and Wanted 0 06-06-2005 10:46 PM
12:01 AM
