Gas tank strap broken - Mustang Evolution
Old 01-25-2016, 05:34 PM   #1
ascottg96's Avatar
How safe you think it is to be driving my 2000 with only one strap holding my tank on. Today I saw one of the straps had been lose. The bolt came out cause of rust and I don't know if it'll go back in at all. What should I do?
ascottg96 is offline   Reply With Quote
Old 01-25-2016, 06:49 PM   #2
Project Pony's Avatar
I'd personally park it and fix it. It might not be a huge risk, but the results if it lets go will be much more severe and costly. Should be a fairly easy and cheap fix. Post some pictures so we can see what needs to be done.
Sent from my SAMSUNG-SM-G920AZ using Mustang Evolution mobile app
[SIGPIC][/SIGPIC]
Old 01-25-2016, 07:20 PM   #3
ascottg96's Avatar
See it's my daily for the winter, and I really don't want to take my summer stang out yet...I'm fixing it tomorrow afternoon. Just us to make it till then
Old 01-25-2016, 10:03 PM   #4
LMR sells replacement straps for ~$40. Keep in mind that a loose tank rattling/bouncing around may cause your fuel pump/sending unit to have problems. If you can help it don't drive it, but seeing how it is your winter dd, I'd take it easy on your commute.
Old 01-26-2016, 01:16 PM   #5
ascottg96's Avatar
Couldn't really fix it, the bolt came out cause of so much rust. Did a make shift job and used hose claps to fix it. The gas tank is also leaking. Don't really feel like fixing cause the car isn't worth that much to start off with
Old 01-26-2016, 01:43 PM   #6
Jbone007's Avatar
Will be worth a lot less if it catches fire due to a gas tank leak, would fix that asap!
Jbone007 is offline   Reply With Quote
Replacing ground strap antnvlz1294 1979-1995 Mustang GT 7 03-06-2014 10:36 AM
ground strap placement 3stangs 1979-1995 Mustang GT 4 11-14-2013 02:41 PM
Gas smell after full tank of gas 93mstnglx 2.3 Mustang 15 02-11-2013 10:37 PM
Ground strap Woodga16 2011-2014 Mustang GT 3 09-13-2012 07:30 PM
No Camera Strap? stangin99 The Bar 7 10-29-2003 11:53 AM
08:58 AM
