Idle issue - Mustang Evolution
Old 02-16-2016, 08:00 PM   #1
Idle issue
I have a 2002 3.8l and after driving the car around enough for it to fully warm up and then going to let's say a gas station running in and then coming out and starting car it has began to run a little funny... but only when fully warm... and not for long... like 3 min max... Idleso like it's struggling for something... has unmarried exhaust and intake only... car has done fine till a few weeks ago... now idles really ruff in this situation but only for a min or 2 then the idle will catch up it feels like and be fine... heard maybe an cam sensor and shaft or maybe crank sensor or maybe a temp sensor not to the gauge but to the motor...
Charlie8Waffles is offline   Reply With Quote
Old 02-18-2016, 12:35 AM   #2
JudenInduven's Avatar
Have you tried cleaning the MAF? And the new filter on the intake may have been over-oiled
The chargers are slugs lol
2001 3.8L - Cheap SR CAI, SF4/X4 w/ 91 Octane Bama Tuning, Pacesetter H-pipe and Borla Stingers, Auburn HP Limited-Slip Diff, FRPP 4.10 gears
Coming EVENTUALLY: BBK headers, Eibach Springs, FRPP Aluminum Driveshaft, Maximum Motorsports Caster Camber Plates
JudenInduven is offline   Reply With Quote
Old 02-18-2016, 01:06 AM   #3
Mile high JDF's Avatar
Holy **** it's another Colorado guy.
I'm curious what your fuel pressure is like when it happens. Maybe you have a failing relay or pump?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-18-2016, 07:09 AM   #4
The intake and air filter have been on the car almost a year... it is a fender well intake and I have checked to make sure it's staying dry and clean... I'm not sure what's happening to the fuel pressure... but I wonder the same thing except I've been told of the fuel pump was having trouble the problem would get worse as I drive not just go away... and I mean go away like it didn't even do it at all... that is till the next gas station stop... lol... again lasting only a min or 2 but it runs sluggish and the motor is idling hard enough to shake the car like its running a big block... and heck yeah another colorado guy... I'm in the springs... wbu? Green stang with black hood and **** it sticker on windshield is me
Old 02-18-2016, 07:16 AM   #5
I'm in thornton myself. It couldn't hurt to check fuel pressure and is a good starting point even if it turns out good.
Old 02-22-2016, 08:59 PM   #6
Dillon_fitz16's Avatar
Following this thread because I'm having the same issues
Dillon_fitz16 is offline   Reply With Quote
Old 02-29-2016, 06:20 AM   #7
Feather_Not_Dot's Avatar
I'm having the same issue on a 02 v6 without anything done to it.....yet. So it couldn't be because of a air filter or intake.
2002 3.8l v6 automatic
Feather_Not_Dot is offline   Reply With Quote
Old 02-29-2016, 09:43 AM   #8
Have you replaced your factory air filter? And even without changing your intake, the MAF can still get dirty, which is a common culprit of idling issues
Old 03-03-2016, 10:14 AM   #9
Yes I have. I've replaced the air filter and MAF
Damn idle. IAC/TPS problems? Idle screw? Help! v8pony 1996-2004 Mustang GT 3 05-22-2015 02:39 PM
Set Idle Screw / Idle problem v8pony 1996-2004 Mustang GT 8 05-15-2015 11:07 PM
95 gt rough idle and bucking issue Napoleon 1979-1995 Mustang GT 15 01-16-2012 05:09 PM
low idle issue Birdcoupe8998 1996-2004 Mustang GT 2 05-19-2008 03:28 PM
Odd idle issue today SpectorV Pre-2005 V6 Mustang 0 05-03-2005 12:42 PM
07:09 AM
