axle swap - Mustang Evolution
Old 03-09-2016, 07:36 AM   #1
Greg687's Avatar
Region: New Mexico
axle swap
Finally found a rear end for my V6. Guy is parting out a 2001 GT and I can have the rear end for $250. Should fit fine, right? Anything I should be looking for when I pick it up?
Meanwhile, I have good, used 7.5 traction lock I never installed... Maybe one of the local 4x4 guys will want to buy it.
Greg687 is offline   Reply With Quote
Old 03-09-2016, 11:23 AM   #2
It will bolt directly in, no problem. Brakes, axles, mounting points are all the same.
Unless you know the exact mileage of the differential and how the car was treated (beat on, tons of burnouts etc), I would plan on cracking it open and inspecting the differential at a minimum. There's a good chance you'll have to get a bearing rebuild kit and/or a tlok rebuild kit. The rebuild kits run ~$80-100.
If it is a higher mileage unit I would try to negotiate a lower price. If you do a rebuild kit it may also be a good time to get different gears if it still has the factory 3.27's.
Old 03-09-2016, 01:00 PM   #3
Greg687's Avatar
Region: New Mexico
Car has 130k on the odometer. Guy is doing a Mach 1 build and parting out a running driving gt. Cheapest 8.8 I've found here is $450 with 200k miles, so this seems a bargain to me. I already have fresh gear oil and modifier I had planned for the 7.5 tlok install, so at least that will happen. The 3.27 gears are an improvement over what I have so if everything is OK I'll leave until it needs to be replaced. Thanks for the feedback.
Old 03-09-2016, 02:51 PM   #4
Well if a 3.27 is an improvement then you have a 94-98 car with the 2.73's?
If that is the case the 99-04 rear will still bolt in but the outer LCA bolts (on the torque box side) are larger on the 99-04 so you will need to drill out the hole locations on your LCA's.
Also the 99-04 is ~.75" wider on each side. If you run or plan on running wider tires like 315's with a lowered stance you may have to roll the fenders.
Old 03-09-2016, 03:35 PM   #5
Greg687's Avatar
Region: New Mexico
Good to know. Car is lowered but don't plan on going that wide. Yes, I have 2.73s
2013 V6 Rear Axle FULL ASSY Swap to 2013 GT Rear Axle FULL ASSY sprdave 2011-2014 V6 Mustang 2 06-16-2015 12:14 PM
For Trade: Roush Axle-Backs for 13+ GT500 Axle-Backs SecretAgent Mustang Parts for Sale and Wanted 3 06-07-2014 06:41 PM
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
does the hub on the rear axle have a gasket between it and the axle? stangcobra Pre-2005 V6 Mustang 15 11-06-2012 04:16 PM
Gear and axle swap questions. DarkShadow Pre-2005 V6 Mustang 15 09-07-2005 02:18 AM
09:17 PM
