EXHAUST HELP ASAP!!!! - Mustang Evolution
Old 03-17-2016, 05:51 AM   #1
Feather_Not_Dot's Avatar
So a weld on my exhaust below the manifold and above the cat bust yesterday. I was told JB weld first then to use some exhaust tape around it to make sure it could get me by for a few months. Need to know if the JB weld is going to catch fire or if I'll be fine using this method. HELP ASAP!!!!!!!!!!!!Click image for larger version
Name:	ImageUploadedByMustang Evolution1458211832.916640.jpg
ID:	198336Click image for larger version
Name:	ImageUploadedByMustang Evolution1458211851.632547.jpg
2002 3.8l v6 automatic
Feather_Not_Dot is offline   Reply With Quote
Old 03-17-2016, 08:14 AM   #2
oxfordwhite's Avatar
Don't mean to be a bummer, but all the JB Weld in the world is not going to help that. You would be expecting an awful lot out of any easy, cheap fix even for a couple of days, or hours, let alone months. I would try to wire brush it clean as best I could, then get in there with a small wire feed and do the best I could to hold me over till I could take it apart and do it right. Make sure to disconnect the battery before you hit it with the welder or you'll fry your ECM.
oxfordwhite is offline   Reply With Quote
Old 03-17-2016, 09:05 AM   #3
Strange Mud's Avatar
Cold Weld Bonding Cmpound : Cargo Thermo Steel High Temp Metal Repair
you can try this (or similar) JB wont work 600 F max. This might as a Yankee Farmer repair. Been there with the $ issues. If you try it give an update either way
Mud
2012 V6 with suspension, shifting, stopping and sound mods.
Old 03-17-2016, 09:08 AM   #4
I'd guess less than 50% chance of working but If I'm right about the situation I'd try it
Old 03-18-2016, 09:07 AM   #5
Try this.
http://www.amazon.com/FIBERFIX-4-Inc.../dp/B00B29A5K8
It's good stuff. Don't race around and heat soak your exhaust and it might hold you over
sledge42hammer is offline   Reply With Quote
Old 03-18-2016, 05:55 PM   #6
I tried the wrap and it didn't hold. I had it rewelded and cleared the check engine light but on my way home from work this morning it came back. It's saying system too lean bank 1 and 02 sensor bank 1 sensor 2. Any ideas what could cause it to reappear?
exhaust
*UPDATED W/PICS* Need help ASAP! 01mineralgrey6 Pre-2005 V6 Mustang 28 03-15-2004 09:41 AM
All PC technitians get in here ASAP...help a fellow PC guy. xtrememustang1 The Bar 13 03-06-2004 02:35 AM
help asap air/fuel ratio gauge install Rstang98 Pre-2005 V6 Mustang 8 03-06-2004 02:17 AM
Need Help with Viruses on my COMPUTER! HELP ASAP!! Autobadges.com The Bar 41 02-05-2004 10:53 PM
Car overheated!!! NEED RADIATOR ASAP HELP!!!! Autobadges.com The Bar 18 11-15-2003 01:36 PM
03:53 AM
