fuel pressure - Mustang Evolution
Old 03-24-2016, 10:58 AM   #1
fuel pressure
hello, does anyone know what the fuel pressure should be? at idle? should it drop any when you hit the throttle? thanks, dan
dcarr is offline   Reply With Quote
Old 03-25-2016, 05:12 AM   #2
Mile high JDF's Avatar
Fuel pressure at idle should be around 35-40 and no it should not go down when you get on the throttle. I take it you're having fueling issues?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-25-2016, 06:19 AM   #3
I'm getting about 35 or so at idle but when I snap the throttle it drops to about 20 and then comes back up. Pulled a couple plugs and they show its running lean. If I take off hard or keep the rpms up its mostly ok but it's during the trying to drive like a normal person that it pops and sputters. I changed the fuel pump last summer.
Old 03-25-2016, 07:12 AM   #4
Yeah that's definitely not right. Do you have any codes? You may have a bad fuel pressure regulator.
Old 03-25-2016, 07:33 AM   #5
No codes at all. I even made it pop and sputter for about a mile trying to make it throw one. I'll look into the pressure regulator. That or the pump isn't working as it should
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 04:32 PM
New oil pressure sending unit, still 0 oil pressure Iryan7 Pre-2005 V6 Mustang 9 07-13-2015 04:15 PM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 06:03 PM
Fuel pressure guage questions eagle05 1979-1995 Mustang GT 4 10-25-2006 05:47 AM
No schrader valve on 05s for wet N2O or Fuel Pressure guage justin00stang 1996-2004 Mustang GT 1 11-17-2005 09:08 AM
01:23 PM
