Engine stalls when hot, need help. - Mustang Evolution
Old 04-03-2016, 02:44 PM   #1
Dasan458's Avatar
Iv got a 2002 Model Convert. I purchased it a year ago wrecked and just finished fixing it. It wouldn't start at first so I narrowed it down to the fuel pump. I replaced the fuel pump motor, and fuel filter. the gas is a little fermented. Its got new antifreeze and engine oil also. It runs great till it warms up. So here is the issue.
The fuel is at 31 psi @ idle.
It overheats a little.
once the needle is past halfway between C & H, this is when it gets wired:
both ABS and TC light comes on along with the right blinker stays solid and front headlight turn on also. When in park it idles fine but once put in gear it stumbles and dies and when I step on the gas is acts like its getting too much air. And when the engine dies I shut the key off and take it out but the lights still stay on and the Odometer shows all dashes.
I pulled 3 codes:
P1233
P1515
P1285
I can erase the codes and they don't show up till the engine gets hot again. I hope this isn't an electrical short because I have to have this fixed by next weekend. Also I know about the antifreeze bleeder valve and I bled it while putting 2 1/2 gallons in so I'm thinking its the thermostat that makes it get hot. Also could all this be a safety feature to keep the engine from overheating?
Chevy runs deep, Ford pulls them out
Dasan458 is offline   Reply With Quote
Old 04-03-2016, 02:48 PM   #2
Dasan458's Avatar
Forgot to ask what the codes mean; and also I can shut the lights off by turning the key to the on position and off again once it happens. Also the TC light doesn't come on on the dash, just on the switch.
Old 04-03-2016, 03:21 PM   #3
natestang07's Avatar
Try that
Old 04-03-2016, 03:44 PM   #4
Dasan458's Avatar
It's not the inertia shut off switch. I pressed it many times and it has not been tripped. If it was that, it wouldn't be running at all. I. Thinking it may be the Fuel pump module???
Old 04-03-2016, 04:15 PM   #5
Definetly still fuel pump related though
Old 04-03-2016, 08:23 PM   #6
Dasan458's Avatar
I think it might have something to do with the CCRM. I know it has a fuel pump relay, and the fan relay? The symptoms do start when the fan starts and the fan stays on but at a low speed when the vehicle dies. This box was exposed to the weather for some time due to the fender not begin on. Can any one confirm this might be the problem?
Old 04-03-2016, 08:42 PM   #7
Dasan458's Avatar
I think I may have solved the problem. I found someone with the exact same problem.
http://www.svtperformance.com/forums...cuts-out-again
Sent from my XT1254 using Mustang Evolution mobile app
Old 04-03-2016, 08:43 PM   #8
Seems like a good start
Old 04-03-2016, 08:52 PM   #9
Dasan458's Avatar
I'll get one tomorrow or Tuesday. If it work or not I'll keep you guys updated. Thanks for the replies @natestang07
Old 04-06-2016, 05:32 PM   #10
Dasan458's Avatar
Update. I still haven't been able to get the parts but now it won't run at all. I took it to the mechanic and he said it was the fuel pump. But idk about that because I can hear it run. He said it sounded like it was gurgling but it shouldn't because there is enough gas it the tank. Also there is 0 fuel pressure at the rails.
Old 04-07-2016, 06:34 PM   #11
Dasan458's Avatar
*Update* I got one from a junkyard and this one is bad too. When the engine stalls the CCRM will click. But the symptoms are also triggered by turning the headlights on. If just the running lights are on I can step on the brakes and the ABS light will blink with the blinker when I turn the blinker on. When I turn it off the lights go out and the engine drives.
Old 04-07-2016, 06:37 PM   #12
Man I'm confused.
Old 04-07-2016, 07:51 PM   #13
Mile high JDF's Avatar
It sounds like you may have a bad ground somewhere
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-07-2016, 08:35 PM   #14
Dasan458's Avatar
Well if that's the case then the problem is "where" this bad ground is
Old 04-07-2016, 09:38 PM   #15
Dasan458's Avatar
*Problem Solved!!!* Mile high JDF was right. The ground wire on the right side wire harness was not grounded. It's the one that bolts into the radiator support in front of the air box and behind the hood prop. Thanks to all you guys help!!
Old 04-07-2016, 09:55 PM   #16
Glad to hear you found it! Does that solve your overheating issue as well?
Old 04-07-2016, 10:09 PM   #17
Dasan458's Avatar
The overheating issue was because I did t have enough antifreeze
Old 04-07-2016, 10:14 PM   #18
Ah ok, I was thinking that the fans weren't turning on
Old 04-07-2016, 10:33 PM   #19
Dasan458's Avatar
Well they were, but we're just turning really slowly. After I replaced the CCRM the fans spin normally. Also the reason why there wasn't enough antifreeze was I filled it up along with the bleeder valve but drove it right away and didn't wait till the water cycled through the engine.
Need help car still stalls. rollo1987 1996-2004 Mustang GT 20 08-06-2014 06:12 PM
2003 gt auto stalls. Need help rollo1987 1996-2004 Mustang GT 2 06-30-2014 10:37 AM
87 trans aod stalls engine in drive please help 87302LX 1979-1995 Mustang GT 11 07-29-2013 07:23 PM
i start the engine and it runs for 5 seconds but then stalls out Pascullon Pre-2005 V6 Mustang 16 03-18-2011 10:41 AM
Rebuilt AOD stalls engine in reverse and only has 1st gear 91StangGT5.0 1979-1995 Mustang GT 5 11-12-2009 04:02 PM
07:01 PM
