Removing starter - Mustang Evolution
Old 04-11-2016, 05:34 AM   #1
Iryan7's Avatar
Removing starter
My starter went out a few days ago on my 01 so I picked up a used one from an 03. After finally getting the top and bottom bolt out, my progress was stopped by a ground wire that didn't want to come loose. Is there something I'm missing or a specific way to get this wire loose? Played with it for an hour and couldn't get the bolt holding it on loose. Any suggestions would be appreciated
Sent from my SM-G920T using Mustang Evolution mobile app
Iryan7 is offline   Reply With Quote
Old 04-11-2016, 02:46 PM   #2
Iryan7's Avatar
If anyone has a suggestion I'd appreciate it as this car is my DD
ID:	199609   Click image for larger version
Old 04-11-2016, 03:05 PM   #3
Iryan7's Avatar
After seeing it today in the daylight I've realized it is the bottom bolt to the starter that has the ground cable attached to it. The "bottom bolt" I thought I removed wasn't even connected to my starter. Guess that's why lighting is important :sly:
For some reason though the bottom bolt will not come out, as every time I try to turn it the ground cable rotates with it.
Sent from my SM-G920T using Mustang Evolution mobile app[/QUOTE]
Old 04-11-2016, 04:40 PM   #4
Iryan7's Avatar
So after a lot of wrenching and torque I got the bolts off but the starter won't fit through the hole. Is it necessary to remove the AT lines? I don't see any way to get this starter out or to unbolt the solenoid wires. Any help would be appreciated
Old 04-13-2016, 10:25 AM   #5
Iryan7's Avatar
I'll have to get the car towed today if I can't get the starter out. Everything is unbolted except the selonoid wires, and I can't get to them because the starter won't come out through hole under the car. If I'm missing a step here or if anyone has any advice I'd appreciate it. 100 views and nobody has replied yet
Old 04-13-2016, 10:28 AM   #6
Strange Mud's Avatar
are you holding the nut that is closest to the starter with one wrench and loosening the other?
Old 04-13-2016, 11:58 AM   #7
Iryan7's Avatar
I got the nut off and the starter loose, but I can't get the starter to come out the hole from the bottom. Do I need to unbolt the two solenoid wires from above or is there a way to get to them from below?
Old 04-13-2016, 12:17 PM   #8
that i don't know
have you tried youtube to see if someone made a vid
Old 04-13-2016, 01:28 PM   #9
Iryan7's Avatar
I looked around and the only videos I could find weren't useful. Just now heading home from work so I'll let you know what happens
Old 04-13-2016, 02:41 PM   #10
Iryan7's Avatar
I can not pull the starter out because the two at transmission lines are in the way. If they weren't there this would be a lot easier. Is it even possible to remove it without removing the lines?
Old 04-13-2016, 03:27 PM   #11
Iryan7's Avatar
Thanks strange mud for your replies but I went ahead and had the car towed to a mechanic. I was so close, yet so far away
Starter solenoid or starter lost need some help Muller 1979-1995 Mustang GT 7 09-03-2013 08:14 AM
Question will a foxbody starter and mini starter Stang.racr 1979-1995 Mustang GT 3 05-08-2011 10:45 PM
Replaced starter in 67 Mustang with a Powermaster High Performance Starter with internal solenoid? rooney Classic Mustangs 3 03-27-2010 08:24 PM
Kelly Holcomb is browns starter!!! MusclesFromBrussels The Bar 2 08-17-2003 09:59 PM
02:56 AM
